Ignition Coil Clicking?
Old Feb 14, 2010 | 04:52 PM
NixLancer's Avatar
It seems like either one or both of the ignition coils in my 04 ES makes a repetitive clicking noise at idle. I don't know if it's normal or not, just wondering if maybe something is wrong. I replaced plugs last year and wires less than a year ago. Thanks for any help.
Old Feb 14, 2010 | 05:16 PM
senate6268's Avatar
Are you sure that it's your coils and not your injectors?
Old Feb 14, 2010 | 07:38 PM
NixLancer's Avatar
No, I'm not sure. Easiest way to tell? If it is the injectors, is there a fix?
Old Feb 14, 2010 | 08:01 PM
senate6268's Avatar
The easiest way to tell would be to get your ear in close and decipher where it's coming from. It's common for the injectors to "click" as they are working. The "clicking" you're hearing might also be your lifters ticking. Does the clicking seem louder at a cold start and sort of quiets down as the engine warms up? Is your oil level good?
Old Feb 15, 2010 | 01:49 PM
Jehuty's Avatar
i've noticed that my car does the clicking if I leave the ignition in the "on" position
Old Feb 16, 2010 | 10:57 AM
drtbiker4lyf's Avatar
Mine does this. What does this mean?
Old Feb 16, 2010 | 05:00 PM
senate6268's Avatar
It's the lifters. Mitsubishi lifters are notorious for this across many models. As the mileage on your engine goes up they get clogged and dirty and need to be cleaned. For them to be cleaned they need to be removed from the cylinder head and soaked in diesel fuel.
Old Feb 16, 2010 | 05:29 PM
Jehuty's Avatar
Whoa edit, I dunno why i was confusing the injectors with something else
Old Feb 16, 2010 | 05:35 PM
NixLancer's Avatar
Nice. I'll have to do this. Pretty simple? Any suggestions?
Old Feb 16, 2010 | 05:59 PM
senate6268's Avatar
It's a fairly involved process. You need to semi-disassemble the head. See the FSM page below.
Old Feb 16, 2010 | 06:56 PM
NixLancer's Avatar
I think I could probably handle it. Is it easy to find the torque specs for when it's time to re-assemble?
Old Feb 17, 2010 | 03:13 AM
Jehuty's Avatar
semi disassemble the head, I thought the injectors were fairly simple to remove
Old Feb 20, 2010 | 07:34 PM
WilliePetesOZ's Avatar
My car does that too but I found out it was the egr solenoids. One of them clicks like its keeping time. Try unplugging on to see if it stops.
xRoguex
Jul 17, 2019 07:50 AM
wowzers
Dec 5, 2018 09:26 AM
EvilEvolution8
Dec 13, 2015 02:34 PM
stunt2
Feb 12, 2012 03:22 PM
villero1834
Lancer Aftermarket Forced Induction Tech
Mar 28, 2009 04:39 PM
