honda sound
Old Dec 11, 2010 | 06:05 PM
kronic420haze's Avatar
honda sound
i just installed a header and i have a cat back and a test pipe so no cats, well when i drive and hit about 3k rpm it makes the most awful rattling raspy sound ive ever heard. my cat back its the n1 style off ebay , could it be a baffel inside the muffler making the sound or is it just from the header, ive had header back exh. and no cats on many other cars and they never made this sound, sounds like a beat up old honda, i dont even want to drive it sounding like this
Old Dec 11, 2010 | 06:29 PM
azinterrider's Avatar
Nice name swap headers and check that would probably tell u where the problem lies
Old Dec 11, 2010 | 09:27 PM
mci2727's Avatar
This is a very common issue that many people with a header and cat-backs have.
I am running a OBX header/mid-pipe and MagnaFlow catback.
I am too cattless and had this issue.
Just found the cure a few weeks ago and will do a write-up soon.
But it is a exhaust leak that only shows it's ugly face at about 3k rpm's and above.
It's either in your header gasket or one of your flang gaskets.
I would call Speed Corps and order a 4G94 exhaust manifold gasket and get thick FelPro flang gaskets.
Replace these and you should be good.
Old Dec 12, 2010 | 09:40 AM
awsome thanks, i hope it works, i did reuse one old gasket too so im hoping thats it
Old Jan 6, 2011 | 10:53 PM
zebra4's Avatar
Put a high flow cat on, had the EXACT same problem on my 05 RA.
Old Jan 7, 2011 | 05:24 AM
mci2727's Avatar
What flange gaskets did you use?
replacing my crappy ones fixed my issue.
Old Jan 16, 2011 | 02:30 PM
shirk's Avatar
yeah my car sounds like this from about 2500-3500 rpm. but not really above.... im assuming its the same problem...
Old Jan 16, 2011 | 06:18 PM
Demon_ni2's Avatar
Exhaust leaks u cant normally hear that loud inside the vehicle. But from what i had issues with was with the brackets.. They would come off, or the whole system would be moved slightly and would rub against the the suspension somewhere, and it would make alot of noise, resembling exhaust noise because it was harmonic with the rpm.. very annoying, and very loud inside the car, and outside also.
If u want to replace ur gaskets, u can look into getting some gasket cloth (may not be the right term) and cutting the gaskets out by hand to make some good gasket making materal.. copper seal and those aluminum looking pin hole 'paper' gaskets that come with the kits are garbage.
Ralli_Red
Aug 3, 2015 12:54 PM
BABYEVO1
55
May 9, 2014 08:18 PM
Ralliart367
22
Jan 20, 2013 01:09 AM
mr9
81
May 2, 2009 07:10 PM
Dwalk08
Lancer Engine Tech
20
Mar 4, 2009 10:20 AM
