Help with whining noise??
Old Mar 19, 2016 | 06:06 PM
k0lok0yboi's Avatar
good look man
Old Mar 20, 2016 | 04:57 AM
FF_Nyck_66's Avatar
Originally Posted by J2K10LANCER
how do you change it do you have a guide that tells you where the drain plugs is....also where to fill it.
I had my local mitsubishi dealership do it. I'm sure you could find a thread on here that has some guidance for that.
Old Mar 24, 2016 | 04:52 PM
rsjust2nice's Avatar
Originally Posted by FF_Nyck_66
Change your CVT fluid. I had the same problem. It was resolved after the fluid was changed!
Do you remember how many miles you had when you changed the fluid?
Old Mar 24, 2016 | 08:10 PM
FF_Nyck_66's Avatar
At that time I believe I was around 45,000 miles. I'm not sure what the service manual recommends off the top of my head.
Old Mar 29, 2016 | 09:40 PM
J2K10LANCER's Avatar
im at 100k and i haven't serviced it yet. yikes
Old Mar 30, 2016 | 11:25 AM
FF_Nyck_66's Avatar
The dealership had recommended it it prior to when i had it changed. But i put it off because i did not have the $ for it. They showed me a sample of my fluid compared to new fluid. Mine was past due. As soon as i had it changed , the whine went away. I was beyond happy that it stopped. Good luck. Hopefully this helped you!
Old Apr 6, 2016 | 10:56 PM
Blue_notanevo's Avatar
You will need a CVT transmission fluid change, best take it to the dealer to get that work done. I had that issue and after the second day the whining noise went away haven't heard it since then.
Old Mar 15, 2018 | 03:24 PM
Mark Romanchuk's Avatar
Gts whine
I'm the owner of a 2009 Lancer GTS 5 speed and my car makes the same wine but it's all the time RPM 0 to 6000 I'm pretty sure it's the serpentine belt they're wider on GTS 2.4 liter just big enough to make a supercharger type sound
Old Mar 16, 2018 | 12:44 PM
Newuser213's Avatar
MAKE SURE MAKE SURE if you do a transmission oil change, also do the transmission oil filter change. It should cost you $200-300 total... =(
Old Mar 17, 2018 | 07:31 PM
Newuser213's Avatar
The Mitsubishi Lancer... Drives like a low class sedan but cost like a luxury sedan to repair/maintenance.
I don't think I'll ever buy another Mitsubishi. Repairs are giving me headache(pricing & reliability/availability).
Old Mar 27, 2018 | 01:40 PM
LancerNation24's Avatar
Originally Posted by jrsimon27
Update: i changed the cvt oil and whola no more whining noise i drive the car hard and everthing is back to normal iam so happy!! Thanks guys for the help!
Did you change your cvt oil at the dealership or did you use an aftermarket brand that is equivalent or better Cvt oil?
megamind
Dec 22, 2017 02:31 AM
W0LF
Aug 9, 2017 07:59 PM
Kaveeth
Jun 25, 2017 04:25 PM
ghost911
Jul 23, 2016 08:08 PM
Dimonstva
Lancer Tranny/Drivetrain Tech
Mar 23, 2016 10:40 AM
