vac gauge question
Old Dec 27, 2003 | 05:02 PM
.L.'s Avatar
.L.
Question vac gauge question
well we just got done installing a vac gauge on my buddy's oz. just wondering if anyone knows what reading it should be at. i think currently its reading at 7 hg ..... does this sound about right? the tubing got a little bent while installing, but replacing it will be no big deal if thats the case. i think my old integra read about 20 or so, thats why i'm asking. ahhhhh well, my buddy's happy with it, but i just wanna double check. any info is appreciated.
Old Dec 27, 2003 | 05:04 PM
blackmantis's Avatar
it depends on the gauge
they are not unlike boost gauges some read in bar
Old Dec 27, 2003 | 09:37 PM
tenkawa_akito's Avatar
mine sits at -20 PSI at idle. as long as you're reading a vacuum at idle, you should be find
Old Dec 29, 2003 | 08:58 AM
HobieKopek's Avatar
-20HG != -20 psi.
You SURE it's -20psi?
Mine idled at about 21hg which is the equivalent of approximately -10psi.
Old Dec 29, 2003 | 09:18 AM
JVlancer's Avatar
my BOOOST gauge reads at -20psi on idle.. but dont got no vaccuum gauge
Old Dec 29, 2003 | 09:33 AM
HobieKopek's Avatar
Check it again. On the negative side it should say InHG. That is NOT PSI.
Old Dec 29, 2003 | 12:51 PM
.L.'s Avatar
.L.
Originally posted by HobieKopek
-20HG != -20 psi.
Hobie.. by chance, where did you connect it too? also is that reading with or without turbo? all he has is exhaust.... everything else it stock, so i'm wondering if that has anything to do with it. i guess i'm use to my integra reading at 20. i did have engine work done though. just seems different i guess.
Old Dec 29, 2003 | 05:28 PM
gokusupersaiyen's Avatar
mine reads -18 hg" or around there at idle
Old Dec 29, 2003 | 05:46 PM
dammit andrew, it's cold outside and you made me go look and the stupid fine fine print does read Hg, not PSI. So I'm running -20 HG.
Old Dec 30, 2003 | 07:34 AM
HobieKopek's Avatar
Betwixt the intake manifold and FPR on a T, my good man.
Old Dec 30, 2003 | 10:33 AM
.L.'s Avatar
.L.
thanks for the help. i'll check it out next time i see him.
Old Dec 30, 2003 | 10:41 AM
HobieKopek's Avatar
Anytime. If you can't find the vac line lemme know. It connects at the bottom of the plenum on the passenger side at one end and the on the FPR on the other. Just get a T from an auto parts store or something and you should be fine.
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Oct 28, 2010 09:00 AM
SpeedI2acerX
Nov 14, 2008 11:46 PM
bigfishs
Sep 16, 2005 09:47 AM
djmikeymike
Jun 12, 2005 04:52 PM
lynkz
30
Sep 24, 2003 01:47 PM
