max engine rpm
From what I understand is that our motors can handle another 800 rpms without any probs. I think R/R set up there ECU reflash 500 over stock. Even thought the 4g94 is a balanced motor from the factory, 9000 rpms is going to kill someone. especially if they are close to the car. Did you see how skinny the rods are? But from I understand that up to about 700 rpm above stock the Lancer still pulls
im sure it'd still pull after that, but remember, after 5500 rpms were still loosing power based on every single stock dyno we have.
so safter so many RPM's it'd be better to shift up than to keep it in that gear...
i only know 2 cars runnin 9k rpm redlines....the s2000 and the rx-8
hey drive, even though we lose power after 5500rpm, we would still be pushing higher hp than if we shifted up. and if we had another 500rpm's or so, when we upshift, we would be at a higher rpm than normal. so we would shift into more hp than normal. so although we may lose some hp, essentially the extra rpm's would be beneficial. correct me if i am wrong, but shifting a little higher doesn't sound bad to me.
oh and i believe their are different rev limiter settings for each gear. no, i don't go around redlining all the time, but i did learn to drive stick on this car. so i have made mistakes, and from personal experience i think they have slighty different settings for each gear.
Originally posted by bahamut
There is no power that high in the rpm band due to the intake mani, exh mani, and cam profile.
'afford to the extremes' they only spent $5k bro...
if u get the RRM Headers, a Test Pipe, Cat-back, and the intercooled turbo, u've spent $5k+ and are only in the 14's...lol
albeit im sure with the 4g94 you'd have to go ALL custom and it'd cost more than $5k to do it...but in the end performance wise were dropping $8k if we go RRM's way and were hitting high 13's like Boe used to....or just low 14's maybe
The RRM reflash raised the rev limiter to 6900, and I have not had any trouble after finding it a few times on autocross courses. But then again, I don't spend much time up there.
LCS
Jul 11, 2016 09:16 AM
RotorGlow
11
Aug 26, 2009 03:38 PM
