Car wont start need help
Old Dec 6, 2011 | 02:29 PM
qaz003's Avatar
ok like i said before car just stopped on me...and is now doing this...any help PLEASE this is my DD
http://youtu.be/NgNzY0N_z8c
not really sure how to post vids but yep thats my car...CPS maybe??
Old Dec 6, 2011 | 03:34 PM
03lances's Avatar
Um maybe its just the angle change from the camera but did the cam gear stop moving when the cranking changed sound?
Old Dec 6, 2011 | 03:36 PM
03lances's Avatar
If so you have some stripped teeth on that timing belt and possibly a very bad day
Old Dec 6, 2011 | 03:55 PM
qaz003's Avatar
ok...yes it did..i think its the timing belt as well...next question...our engines...free running??? lol hopefully i didnt **** some **** up
Old Dec 6, 2011 | 04:43 PM
03lances's Avatar
Free running as in non interference? No unfortunately if the timing belt breaks there is a high chance of engine damage. I will quote from another thread I posted in.
Originally Posted by 03lances
Here is what I would do. After you pull the old timing belt off rotate the bottom end to TDC. Then turn it back a 1/4 turn. This will keep all the pistons below the block surface so incase you were lucky enough not to do damage in the initial event you wont do anymore. Make sure you DO NOT rotate the top end until the bottom end is set. Next turn the cam shaft to get it to TDC. Then turn the bottom end back up to TDC and install the new timing belt.
Its most definately out of time right now. The top end stopped instantly when this happened but the bottom end turned for a little longer. Not to menion you have cranked on it since then You cannot do anymore damage than is already done using my method above. Good luck man hit me up if you have any questions I have done this lots and lots of times
Here is a quick writup for aligning the timing marks.
Just to be sure you lined up thses marks correct?
Also when installing the timing belt you want to start at the cam and follow the engine rotation keeping the belt tight of course so from the cam sprocket >water pump > crank gear > then slide it over the tensioner pulley. then make sure to slightly rotate the engine just maybe a 1/4 turn with that tensioner loose so all the slack gets soaked up by that spring on the tensioner pulley to have to correct belt tension. Then tighten the pulley up and rotate the engine at least twice to confirm the marks line back up good luck
Old Dec 6, 2011 | 04:55 PM
qaz003's Avatar
what kind of damage can i expect...i have tried starting my car quite a few times as well since it died
Old Dec 6, 2011 | 06:05 PM
03lances's Avatar
Best case scenario is you are blessed and somehow the valves and pistons missed each other (not impossible I've seen it happen) and you install a new belt and off you go using my method described above. Worst case.. start searching junkyards for a new engine my friend. I would start by buying a new belt and using my method above install the new belt then do a compression test. This will tell you if there has been any damage. If compression tests good then your set. If it does not you will be pulling off the cylinder head to see if its just bent valves or pistons damage as well.
Old Dec 6, 2011 | 07:42 PM
CrAnSwIcK's Avatar
it's possible there is no damage...replace timing belt and check compression, if good...try starting it.
Old Dec 7, 2011 | 04:13 AM
qaz003's Avatar
alright will let you know how things go...will change the belt and water pump this weekend and check the compression...
man now i have my bike to fix as well...i think water is leaking into gas tank WTF haha what a week
Old Dec 7, 2011 | 11:23 AM
03lances's Avatar
Tell me about it man lol. You dont wanna know what my last week has been like. Fingers crossed for ya man lets hope there is no damage
Old Dec 11, 2011 | 04:21 PM
qaz003's Avatar
well...got everything off except the damn crank pulley bolt...anyone know where you rent an impact wrench...or any other option then trying to start the car cause all belts are off right now
Old Dec 11, 2011 | 04:32 PM
corndog17's Avatar
Get a long pipe on the end of your half inch drive ratchet like a 3.5 footer. Spray some penetrating oil on the bolt behind the bearing face. And make sure you prevent the motor from turning by jamming a pry bar or not screwdriver in the flywheel under the car. Break the bolt loose. I actually too the oil pan off and jammed a pry bar in between the block and the crank which made it unable,to rotate and break loose. Or u can rent a impact and not have to worry about the motor rotating as your trying to break the crankshaft pulley bolt loose.
Old Dec 13, 2011 | 02:57 PM
qaz003's Avatar
finally got the damn bolt off lol
Old Dec 15, 2011 | 03:13 PM
qaz003's Avatar
ok i got everything on...and still will not start...the crank i had timed right but the cam sprocket i could not align perfectly with the mark...it was either a 1/4 inch behind it or 1/4 inch in front of the mark...could this keep it from starting...need help
Old Dec 15, 2011 | 04:04 PM
corndog17's Avatar
My timing marks weren't lined up perfectly niethier. The dot on the crank sprocket wasn't lined up perfectly with the arrow on the oil pump it was off by a tooth. Should be fine as long as its pretty close to the mark.
