help installing a turbo
hey guys, looked at some of the forums on here about installing a turbo on an ES....still kinda lost. can someone give me a good link, with pics, that can help me out on the install. a fellow enthusiast on here wants to sell me a turbo. any help would be much apprecaited
Link is in my sig homie check it. Also these
https://www.evolutionm.net/forums/la...ncbs-turn.html
https://www.evolutionm.net/forums/la...o-8-build.html
https://www.evolutionm.net/forums/la...questions.html
https://www.evolutionm.net/forums/la...o-project.html
and many other like these. Really easy to find esp when you look in the right places
This should be in the forced induction section too btw.
honestly, a decent parts list that i can work with.... im running an A/T. i would like pretty much the max amout of boost and Hp i can get without having to rebuild the motor to put forged internals in...im new to the whole tuning scene... so yea.. a decent parts list would be amazing.
shoot for 250hp if you don't want to build the motor...
you need:
exhaust manifold
turbocharger
downpipe
wastegate (internal or external)
oil feed/return lines
larger injectors
intercooler and piping
blow off valve
fuel pump (maybe)
for engine management, it depends on what you use, that will determine what else you need, not sure if the 4G94 guys are using MAP sensors for tuning. And a wideband air/fuel gauge is a good idea.
of course you'll need oil feed/return fittings and sources, as well as boost and vacuum sources...
This is like the 5th thread you started asking about this same topic...i don't know what you're looking for, maybe you're just trolling for the lulz, or you are actually too lazy to search and read the forum.
You don't need to come on here and ask what you need for a turbo conversion, you can get this information ANYWHERE else on the internet...If you're looking for brand names, etc. Use google, read reviews on parts.
I've said this in your other threads, the only vehicle (lancer) specific parts are the manifold and injectors...everything else is pretty much universal...
you need:
exhaust manifold
turbocharger
downpipe
larger injectors
blow off valve
fuel pump (maybe)
also what are some of the issues i could run into while installing a turbo on my 03 ES with A/T? u mentioned vacuum and boost sources? what exactly are those? im only asking because i dont know
barelyboostin
Aug 19, 2008 12:16 AM
