timing adjustments?
Old Nov 12, 2012 | 06:49 PM
onelozu's Avatar
timing adjustments?
is it possible to adjust the timing on the 4g94 in my 03 oz? before this i had a mighty max with the 4g64 and after adjustting the timing it had a bit more pep,but of course that had a distributor and the lancer doesnt which brings me to my question. any help would be appreiciated
Old Nov 15, 2012 | 03:51 AM
Blackstar37's Avatar
It is computer controlled.
Old Nov 24, 2012 | 09:47 AM
CrAnSwIcK's Avatar
ignition timing can be controlled via ECU, valve timing is purely mechanical...i haven't looked into anything for my 2003 4G94 lancer, but on my 4G69 Ralliart, i'm running a turbo setup on the stock ECU by remapping (reflash). I believe there is tuning software that works with your ECU...
Old Nov 24, 2012 | 03:03 PM
jakermeister's Avatar
unless its MIVEC you can't control the valves
Old Nov 25, 2012 | 06:35 AM
CrAnSwIcK's Avatar
i can control when mivec engages, or if it does at all...
Old Nov 25, 2012 | 04:09 PM
Green_Bandit's Avatar
So mivec tuning is no longer a problem for the Ralliart guys?
Old Dec 16, 2012 | 05:04 AM
trfguy's Avatar
Original poster is referring to ignition timing. On the old 4G64, you were rotating the distributor to advance the ignition timing. You could do similar with adjusting the cam position sensor, but unfortunately, it is fixed. I suppose if you really wanted to get creative and slot the holes, it would work. However, be careful, to much advance, and you'll create engine killing pre-detonation.
Old Nov 16, 2023 | 10:17 AM
That09galant's Avatar
works this work for my 09 galant with the 4g69??
jimbo74
Lancer Engine Tech
Apr 21, 2016 01:59 AM
4G63_EVO
Jun 16, 2014 03:01 PM
4G63_EVO
May 9, 2014 06:01 AM
superalf574
Aug 13, 2009 12:53 AM
The Admiral
Dec 16, 2004 03:12 AM
