maf sensor mod
Old Mar 3, 2004 | 10:06 PM
rhyzin's Avatar
if you haven't been around, i'm as close to that as it gets.
i used to run with a restrictor plate that was 2.5"x2.5" square. any larger and it won't work. fuel mods are necessary. i now use the 3G eclipse MAS. it's smaller than the modified MAS, but i'd rather run something unmodified. it's still larger than the stock MAS tho. depending on mods later down the road, i'll probably upgrade to an evo 8 MAS.
Old Mar 3, 2004 | 10:45 PM
bahamut's Avatar
Piggyback ecu or reflash assumed that you are running a normal MAF, not a hacked one. Thereby, their upgraded perimeters won't work, usually for basic mods.
Besides, both system bypasses the AFC.
Rhyzin,
You mean the 339 MAF (hopefully got that number right). That would be interesting.
Old Mar 3, 2004 | 10:56 PM
rhyzin's Avatar
there really is no need to go to the 399, but would be one of my last NA mods. a precursor to turbo
Old Mar 4, 2004 | 05:52 AM
airlinevomitbag's Avatar
The slightest changes in that bezel make HUGE A/F changes. Hell even moving that screw out which is about 3/8" wide by a 1/4" tall makes big differences in your mixture.
Ryan42099
May 23, 2017 10:45 AM
suprPHREAK
Toronto Lancer Club
62
Dec 15, 2016 10:17 AM
markspd6
For Sale - Wheels / Tires / Suspension / Brakes
Dec 5, 2016 04:27 PM
Shanedixon1987
10
Jan 24, 2016 07:11 AM
AlvinHuyN
May 14, 2008 12:49 PM
