Help me build my 2002 LANCER ES :/
Old Jan 15, 2014 | 09:22 PM
  #31
RaCh3T8G's Avatar
B&M has one for $60.
Old Jan 15, 2014 | 09:27 PM
  #32
Thahomeboyb's Avatar
Okay not bad I'll get one .
Old Jan 15, 2014 | 09:36 PM
  #33
Caring wait to blow all thus money on my car
Attached Thumbnails Help me build my 2002 LANCER ES :/-image-3439457068.jpg
Old Jan 16, 2014 | 09:13 AM
  #34
Green_Bandit's Avatar
Dude! For the last time. If you are serious about turboing, research before you spend the next dime! You are swinging in every which way. People telling you things that aren't beneficial to the build or are unnecessary at this stage.
Old Jan 16, 2014 | 09:15 AM
  #35
02modlanceroz's Avatar
Originally Posted by RaCh3T8G
I thought the auto ecu's weren't reflashable at least that's what i read somewhere in one of the threads on this site which is why i mentioned getting an evo ecu. A trans cooler keeps the transmission from overheating which would be a good idea for you to run do to the extra load it'll have once you go FI.
People are running tunes on their auto ecu's and running turbo setups with 12psi or greater. They are just modifying their current ROM file that they have for the ECU. From What I read in the past, I haven't looked lately because it doesn't pertain to me. No one had tried to flash and Evo ROM into an auto because their was fear of the bricking it, and from my understanding, there was a lot of thought that went into for trying to put the Evo ECU into an auto lancer. From what they figured out, that wouldn't be possible. I know of one person that did the ECU swap, but that was done in a manual and it was done prior to knowing that manual cars could just be flashed with an Evo ROM
Old Jan 17, 2014 | 11:02 AM
  #36
mace1890's Avatar
Yeah I wouldn't worry about a tune or any other add on at all right now your not going to feel any difference. Just save up and read up on a turbo system.
Old Jan 20, 2014 | 08:42 PM
  #37
Just got paid ! What should I do next to my car ? Racing seats
Tail lights
New car speakers
Springs
Idk what else ? Please give me some suggestions!
Old Jan 20, 2014 | 10:07 PM
  #38
SilentCool's Avatar
Tail lights
New car speakers
Springs
I would go with suspension, at least get the car handling a bit better. Probably rear sway bar for starters. How does that sound?
Old Jan 21, 2014 | 12:16 AM
  #39
RaCh3T8G's Avatar
Ahh ok. I'm originally a Galant guy so i know when boosting the galant you have to swap to either an eclipse or evo ecu for tuning since the galant ecu cant read anything above 100% load so i figured it was the same for the lancer but i guess that's been figured out for you guys.
Old Jan 21, 2014 | 01:21 AM
  #40
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
lol i bought a 1991 DSM 4g63T awd turbo talon tsi for 800$ on craiglist, fmic for 300$ full 3" TBE and its a blast to drive, but hey...... to each thier own i guess...... GOOD LUCK W/ your project
Old Jan 21, 2014 | 03:47 AM
  #41
Yeah gunna go with suspension
Old Jan 21, 2014 | 06:35 AM
  #42
*02Lancer*'s Avatar
Or start buying parts for your turbo build or swap. just pick a goal and stick with it even if it takes $ and time trust me well worth it. I have been working on my swap for awhile now and to fire it up and pull it out is such an accomplishment. To prove that it can be done and done cheap. good luck with build keep us posted
Old Jan 25, 2014 | 08:58 PM
  #43
I got a new job so going to be buying a lot more parts for the car
Old Jan 27, 2014 | 07:19 PM
  #44
edit
Attached Thumbnails Help me build my 2002 LANCER ES :/-image-1397594538.jpg
Old Jan 28, 2014 | 09:35 PM
  #45
USCGSAM's Avatar
my design for the custom sub box I am making for my trunk.
I'm going to use pioneer kick subs 40.00 (x4) Boss amp 50.00
The amps are going to be raised about 2.5 inches from the board ( by using fiberglass) where the amp is going to be located. The wood I'm going to be using is Mwd I'm picking it up from Home Depot tomorrow!
Then I'm going to buy another carbon fiber vynl and over lay it on the fiberglass. Then on top of the vynl I'm going to have some jdm stickers,logo and part stickers.
Then around the amp I'm going to put some blue led strips . Would love to hear some feedback
just curious are you doing this simply for style, car show points or are you also tryning to have a good sound system?
i have a kicker L3 solobaric(square) sub powered by a 1000 watt amp in my car and it sounds amazing.
. if your doing it for style , good luck with your project and take your time fiberglass is a HUIGE PITA if you have never done any thing like this before.
