idling issues
Old Aug 6, 2015 | 10:35 AM
jb988's Avatar
idling issues
Can anyone offer advice on this problem I'm having? When I'm at a light and hold the brake in my car idles at a low rpm and sometimes the engine just shuts off any ideas?
Old Aug 6, 2015 | 11:42 AM
jakermeister's Avatar
Any check engine lights? Is it only when you press on the brake?
Old Aug 6, 2015 | 12:40 PM
jb988's Avatar
no check engine lights and for the most part it is really when i have the brake pushed in but recently i have been just sitting in the car and then after some time it gets really low in revs and then just stalls. any way it could be a dirty throttle body?
Old Aug 6, 2015 | 01:50 PM
Could just be slack in the throttle cable?
Old Aug 6, 2015 | 03:17 PM
OMEGA PHX's Avatar
Clean your TB and your maf sensor.
Old Aug 6, 2015 | 04:45 PM
jb988's Avatar
i was thinking that it might be slack in the throttle cable as well because i had felt it a bit loose before. I'm not entirely sure how to tighten it.
Old Aug 7, 2015 | 09:50 AM
Keep it simple then move on to other possible solutions. Just look at the cable. Typically you'll need a wrench.
Old Aug 10, 2015 | 07:10 PM
CrAnSwIcK's Avatar
could be a vacuum leak as well, purge solenoid stuck open will cause that for example...
dorian7
Dec 22, 2008 09:36 PM
JWhat89
Lancer Engine Tech
10
Oct 29, 2008 07:21 PM
Sixspeed J
Jul 18, 2008 08:37 AM
Inprogress
May 8, 2008 03:43 PM
EVO-genetik
Lancer Engine Tech
Jul 4, 2006 05:51 PM
