engine noise
Old Dec 23, 2016 | 01:03 PM
  #46
jb988's Avatar
So I was on Craigslist and on my home town I found a Lancer Ralliart with front end damage for 500 dolalrs. He says it can run and drive home. Would this be a good source for an engine to swap over? Thoughts? I know the 4g69 is a bit different but if I have an entire parts car to source from is this feasible?
Old Dec 26, 2016 | 04:50 PM
  #47
CrAnSwIcK's Avatar
yeah...mounting should be pretty close. although the 4g69 is fuelled by a returnless system, and iirc the 4g94 has return lines...correct me if I'm wrong.
Old Dec 27, 2016 | 12:09 PM
  #48
jb988's Avatar
I'm not sure but It may be true because in one swap thread I read, they mentioned having to switch over to 4g69 fuel pump. Would this be the reason why?
Old Dec 28, 2016 | 06:47 AM
  #49
CrAnSwIcK's Avatar
not sure, I don't recall where the return line goes...but the fuel pump is easy replace...our fuel injectors are only 305cc, I can't see why the pump from the 2.0L wouldn't work...
edit*
Just out of curiosity, I checked ASA and the 2.0L and 2.4L use the same fuel pump...
Old Dec 28, 2016 | 07:38 AM
  #50
jb988's Avatar
Man crans your always so helpful. Why can't you live in Texas. I feel I should start a new thread dedicated to the 4g69 swap what do you all think
Old Dec 30, 2016 | 10:31 PM
  #51
CrAnSwIcK's Avatar
you'll need the ECU and the complete engine harness.
Old Dec 31, 2016 | 11:01 PM
  #52
jb988's Avatar
I'm going to buy a whole car with Frame damage. So I should have everything. Including axles
Old Jan 2, 2017 | 11:10 PM
  #53
jb988's Avatar
Bought the ralliart for 400 dollars!. Now we gotta start taking them apart
Old Jan 5, 2017 | 09:33 AM
  #54
jb988's Avatar
I have both cars next to each other now in my back yard. At this point I have the radiator, airbox, fuse box, ecu, and harness from the fuse box to the alt, starter, fuel rail, spark plugs, and transmission. Should I start a new thread or continue here? and if start a new one what forum should it go in?
Old Jan 5, 2017 | 09:53 PM
  #55
CrAnSwIcK's Avatar
I would do a new thread...03 lancer 4g69 swap...or something like that...
Old Jan 6, 2017 | 10:52 AM
  #56
jb988's Avatar
But should it go in the Lancer forums or the Ralliart forums?
EEVOH
14
Oct 12, 2013 09:08 AM
prowakeskater
May 15, 2011 09:13 AM
evotris
13
Jun 27, 2008 04:22 AM
threefiftyse7en
Aug 24, 2007 02:37 PM
BEANIE
16
Oct 24, 2006 06:08 PM
