No-CEL header?
Old Jun 23, 2004 | 06:08 AM
andy's Avatar
As long as you have one O2 before the cat and one after your good to go, I purchased four different color wire and a sodering iron and made the two sensor wires longer. I had a O2 bung welded to the down pipe because a use the other for the wide band.
Old Jun 23, 2004 | 05:08 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Originally Posted by ghostrider
I thought the o2 sensor wire is too short to flip the cat around?
well, that sucks a little, but could be fixed with about 60 cents worth of wire and a little solder wrapped in electrical tape. Just cut the wire and solder an extra couple of feet to it. Even an idiot like me could do that!
Like I said though, that won't pass emissions, it will just keep the CEL from lighting up.
Old Jun 23, 2004 | 05:43 PM
Blacksheepdj's Avatar
*cough* Welcome to Ohio! *cough*
We no longer check emissions on OBD2 cars. They just plug in and make sure it's clear. As long as there's no CEL, you pass!
So for Ohioans, it would pass.
Old Jun 26, 2004 | 10:32 AM
iyi0521's Avatar
its the same in Pa. just a plug and play. No CEL? Have a good day. Not sure about inspection tho. they might throw a fit about it.
Andrei Spelciuc
Lancer Engine Management / Tuning Forums
Dec 11, 2015 11:07 PM
blackonblackevo
Feb 7, 2007 11:03 AM
ooralliartoo
55
Jan 6, 2006 05:35 PM
cutieone
Aug 23, 2005 10:54 PM
hawwk11
Mar 21, 2005 03:18 PM
