need cam info
Old Aug 13, 2004 | 08:21 PM
lancerdrifting's Avatar
Talking need cam info
i need some info on some new cams. i wanna make my lancer dual cams but im not sure if it that easy. or if its even possible. and i also want to kno how much cams r for my car. i cant find n e where that sell them. if u can please help me out i wanna start catchin up to my friends eclips quik.haha ok thanks
Old Aug 14, 2004 | 07:09 PM
Mitsiman's Avatar
You cannot convert to duel cams.
There are an improved single camshaft available from RPW and if you go to our website you fill find links to our USA dealers who can give you pricing.
Old Sep 17, 2004 | 05:19 PM
fastmitsu18's Avatar
Registered User
why not? mirage guys have swaped the dohc heads onto their blocks. why can't lancers do the same?
David
Old Sep 17, 2004 | 05:23 PM
lookslikeanevo's Avatar
never say never....david is right about people already have done it with the mirages....i believe that there is a 4g93 or a g92 that is DOHC...but if your already gonna go through that trouble then you might as well go with a g64 swap...still sohc but will give you that power you cant just achieve with simple bolt ons
Old Sep 17, 2004 | 07:33 PM
ghostrider's Avatar
The problem with the 64 series engine is that it's from a different family. It might not be as simple as just bolting the new head on. The reason the 93s can swap heads to dohc versions is that they stay in the same family (4g93 with whatever 4g9x series head that's dohc).
On top of that you'll need the ecu from whatever car you do the head swap with since the stock 4g94 ecu won't even be able to comprehend what a 2nd cam is doing.
Old Sep 17, 2004 | 07:47 PM
psy-q's Avatar
I think its the 4G91 DOHC that will bolt right down to the 4G94. Do a search, its here somewhere.
Old Oct 20, 2004 | 08:26 AM
hardcoretuner's Avatar
honestly your not going to know ever until you A) measure the crap out of both heads or B) just go ahead and do it. i don't think anyone knows for sure. odds are that it won't work IMO because we have 2.0 and those are smaller. thats just my opinion though. i hope it does work. but i ask this.. why does it even matter if there is 1 cam or 2, in the end you have the same amount of lobes to work with. a tuned sohc and dohc have the same benifits as one another. dohc alone doesn't make it better, its when people tune them it does. people like dohc so they can retard exhaust timing more or less than intake timing. this same thing can be done with the tuning of the actual cam on a sohc making them the same thing. only difference is sohc has to get a new cam each time they want to change the timing of the intake/exhaust strokes. i don't think it will be worth converting all that just to gain maybe 1-2 hp becuase of fine tuning in the end. just my 2 cents. good luck if you try it.
oh yeah i have cam from rpw, stage 2. it freaking rocks and i feel confident when i say i believe i have the fastest NA AUTO on the forums BUT before i get killed i know i don't have a timeslip so i should shutup, just wait till the track is open mwa ha ha ha lol
peace
Old Oct 20, 2004 | 04:22 PM
Nm0ney34's Avatar
stage 2 on an auto? how is it doing? what are your other mods and what are u using to tune the cams?
oh yeah what do u redline at now...tell me how your powerband is now
Old Oct 20, 2004 | 05:53 PM
03RallyLancer's Avatar
i can answer that he is using emanage... lol
Old Oct 20, 2004 | 07:28 PM
Hotshot940's Avatar
DOHC is not a night and day improvement over SOHC, the gains that you would be given using 2 cams are offset by more mechanical movement. replace the single cam that you have if your going to do that, RPW makes one, not sure about the details tho. if you want to catch up to your friends car, don't waste money on getting DOHC, just get a turbo.
Old Oct 20, 2004 | 07:56 PM
what you mean i can answer that he is using an emanage??? i did have an safc and it sucked fat! the stage 2 is awsome, i have full intake and exhaust systems with valve springs as well. the car has a lumpy idle that i love and its redline is the same because the emanage doesn't change that at all. power is crazy anything past 2.5 grand, when racing it never drops below the main power area and the power is all the way to the redline with very little drop off.
Old Oct 20, 2004 | 08:09 PM
well thats the only thing i knew out of his questions about your car so i answered them... u r using emanage to tune lol
Old Oct 20, 2004 | 08:48 PM
Hotshot940's Avatar
hardcore, are you auto or 5 speed? i'm looking to invest in a turbo cam from RPW if it will work well with my setup, how much did you pay and how hard was the install?
Old Oct 20, 2004 | 09:04 PM
auto, i highly recomend their cams, mine is great
Old Oct 20, 2004 | 10:18 PM
FlLancer's Avatar
how hard are they to install? would you need a mechanic to install it?
