spark plug wires
Old Oct 22, 2002 | 10:37 PM
nycrazy's Avatar
wat do spark plug wires really do?? how do we benefit from them? performance wise? care wise?
Old Oct 23, 2002 | 11:50 AM
[s3]'s Avatar
Plug wires
Transfer power from the coil to the plug to create a spark. These wires are usually insulated with several layers of insulation.
Usually they last quite a long time under normal conditions, if you live in winter climates and have constant heating and cooling they will not last as long.
Any durable wire will suffice, theres really no need to waste money on high performance wires and or plugs.
There is usually very little increase in HP from hi perf plugs/wires, only noticeable on dynos.
Save your $ for better ROI, like headers, exhaust intakes....turbo systems etc..
Old Oct 23, 2002 | 01:57 PM
nycrazy's Avatar
jesus christ...im not gonna buy them things yet...just wanted to know wat they were good for
Old Oct 23, 2002 | 01:59 PM
wags528's Avatar
nycrazy - don't mind him - - i think u should look into getting some wires though - - may not give u extra HP, but overall makes the car run better i think - - smoother idle . . . better starting . . . . etc.
Old Oct 23, 2002 | 02:11 PM
[s3]'s Avatar
Are you serious?
Not trying to bag on ya, but if you changed wires on an almost brand new car, you won't notice any difference whatsoever.
smoother idle? better starting? you serious bout that? You gotta think, if these wires are so good and can do all that with a simple wire change, wouldn't all newer cars come with them already?
Old Oct 23, 2002 | 02:53 PM
pjal84's Avatar
Cost cutting measures abound everywhere in cars. I'm sure a thing like spark plug wires are just one of many.
Old Oct 23, 2002 | 08:42 PM
JohnMemorialHS's Avatar
I think s3's got a point though, it might run a little smoother if noticeable, but nothing too much. It's true a lot of cars cut down on material, but when you have something like BMW or Porsche, why wouldn't they have "high performance" plug wires? They have factory high performance tires, suspension, gearbox, etc. But they're too cheap to go high performance on plug wires? I really doubt that, but hey correct me if I'm wrong
Old Oct 24, 2002 | 06:54 AM
[s3]'s Avatar
Insist on OEM replacements if and when
you do go to a garage or something other than the dealer. If you install something that is proven to cause damage to your car, it will not be covered under warranty.
Ferp
Jul 11, 2016 08:07 PM
justin.AZ
Lancer Engine Tech
Oct 2, 2009 06:58 AM
lancer_styles
Lancer Engine Tech
May 24, 2008 09:59 PM
NOTORIOUSLANCER
Lancer Engine Tech
30
Sep 15, 2007 03:24 PM
therzdae
Lancer Engine Tech
17
Jul 21, 2007 10:19 AM
