ROAD/RACE- Anyone interested in FORGED N/A PISTONS?
Old Dec 10, 2004 | 11:18 AM
  #211
Tweak3D's Avatar
I think that is a doable goal. My personal goal is 160ish at the wheels. Considering that no one has every N/A mod, no one can say how much power you would have. I would guess with the PB, these pistons, flywheel, and intake/exhaust, etc I think you would be damn close to 150.
-Justin
Old Dec 10, 2004 | 12:19 PM
  #212
pgmike's Avatar
our internals are not as weak as you think, we really can boost up to 10psi safely with proper fuel and tuning, and you really have no reason to be worried about the valves and rods unles oyu are pushing way more boost with stock ones but rally your pistons would go first and you would be replacing the valves and rods before that anyways bc they start floating at 12ps but not breaking.
Old Dec 10, 2004 | 12:21 PM
  #213
tonloc745's Avatar
it will be all in the tuning. you'll need a cam and cam gear to get that power. you'll need a vafc2 as well i dought you can use a rrm piggy back. unless they do custom tuning.
Old Dec 10, 2004 | 12:46 PM
  #214
Tweak3D's Avatar
a cam and cam gear will help, but we don't know how much these pistons will help, but if you research you can see the raising compression by 1 point is alot of extra power.
-Justin
Old Dec 10, 2004 | 01:09 PM
  #215
tonloc745's Avatar
not really are cars are 9.2 right now and going to 10.0 will give you 5-8 hp on a stock motor. but if you have a cam you will be able to pull more air. and will help a ton
Old Dec 10, 2004 | 01:18 PM
  #216
Tweak3D's Avatar
who says that you will only get 5-8 HP? everyone who knows anything aobut engines and if you do any research it shows that its possible to get alot more than that by raising the compression this much.
-Justin
Old Dec 10, 2004 | 01:22 PM
  #217
Tweak3D's Avatar
also, like I said earlier, even if it is only 5-8 if it is plu 5-8 throughout the powerband, who cares, its better than taking some from the top and giving it to the bottom, etc.
-Justin
Old Dec 10, 2004 | 01:24 PM
  #218
gregivq's Avatar
tonloc745 if you read the first and the second page of this thread you'll see that 5-8hp sounds kind of funny.
  #219
tonloc745's Avatar
hahaha that is the most mistaken rumor ever in history of building. i have a sohc honda and it had 130whp with 9.2 to 1 compression and when i built it i went to 12.8 to 1 compression and got 26 hp to the wheels. thats going 3.5 points to get 26hp. with these pistons you are going .8 points so go do your research buddy
Old Dec 10, 2004 | 01:25 PM
  #220
gregivq's Avatar
OK here's a solution!!!
Let's finally get all the people in and order the pistons.
And then dyno or time slips will show everything.
Old Dec 10, 2004 | 01:26 PM
  #221
tonloc745's Avatar
yea that i'm right
  #222
gregivq's Avatar
Honda is what 1.6 L or 1.7 L it makes a difference BUDDY
Old Dec 10, 2004 | 01:27 PM
  #223
gregivq's Avatar
and what kind of fuel you're using on your honda? just curious
Old Dec 10, 2004 | 01:28 PM
  #224
gregivq's Avatar
Like I said before it doesn't make sense to argue right now.
I'll be more than pleased to post dyno sheet after I'll get the pistons installed.
Old Dec 10, 2004 | 01:29 PM
  #225
Tweak3D's Avatar
I am not trying to start anything, and first off they are raising it to 10.5 not 10, secondly, our cars have bigger engines than hondas and are built differently. I am not trying to start anything, all I am saying is that if you have found other information, please post it, I would love to read it, but from everything I have found, it shows quite sizeable gains.
-Jusitn
