Dyno RRM Turbo Lancer
Old Jan 30, 2005 | 08:47 PM
  #76
ROCK's Avatar
It was a Magnaflow. They use the exact same Race series SS muffler we do on our axelback. Would not matter much........
ROAD/RACE
Old Jan 30, 2005 | 08:53 PM
  #77
ronsozlancer's Avatar
who installed it for you. did you do it yourself?
Old Jan 30, 2005 | 08:59 PM
  #78
Lancerguy'03's Avatar
yeah i did everything myself and help of friend...who did the same work on his 2.5RS
Old Jan 30, 2005 | 09:04 PM
  #79
thats freeking awesome how long did it take.
Old Jan 30, 2005 | 10:11 PM
  #80
rhyzin's Avatar
don't mind this post. just so i don't have to upload the dyno somewhere else.
Old Jan 30, 2005 | 10:16 PM
  #81
rhyzin's Avatar
oh yeah, what gear did you do your pull in?
Old Jan 30, 2005 | 10:59 PM
  #82
Viciouz's Avatar
he sed 4th didn't he?
Old Jan 31, 2005 | 11:58 AM
  #83
yeah 4th...it took about 2days to install....the clutch and flywheel...we had no idea what we were doing to drop out the tanny...we just looked at it and started unbolting ****....if you think about a car is just bolts...it helps simplify things
Old Feb 2, 2005 | 01:02 AM
  #84
Boeturbolancer's Avatar
that dyno shows you being to lean... go easy on the car till we can get it figured out. Being that lean is asking for detonation issues. Keep me posted via pm's and we'll get you more power with a better AFR. Out of curiosity what was the difference between the first and second runs?? The first run was way lean and out of control.
Old Feb 2, 2005 | 10:06 PM
  #85
How much of a difference would having the piggyback make in WHP? would that fix the problem that hes having with running too lean?
Old Feb 2, 2005 | 10:19 PM
  #86
Viciouz's Avatar
it could but we only use the pb in stage 2 with all the extra fuel added. but in his set up he'ld have to have a specific tune for himself
Old Feb 2, 2005 | 10:33 PM
  #87
rhyzin's Avatar
if you have a problem, you should address it first instead of trying to cover it up with another mod.
Old Feb 2, 2005 | 10:57 PM
  #88
ROCK's Avatar
Stage 2 is Stage 2 not a fix. Check for vacuum leaks to FMU. You may have a leak.
ROAD/RACE
CombatSpeed
Lancer Aftermarket Forced Induction Tech
22
Jun 15, 2015 10:07 AM
rhyzin
Lancer Engine Tech
270
Nov 28, 2014 10:02 AM
Ralliart_on_LSD
602
Nov 25, 2008 07:08 AM
RarStlzLncr
For Sale - Cars For Sale
May 22, 2008 03:24 PM
MIA2FASLANCER
Mar 23, 2006 09:17 AM
