Still having problems w/ cf hood install...
Old Apr 7, 2005 | 02:54 PM
Kelspar's Avatar
Ok i have the evo 7 bumper installed and it seems to be fine. but when i went to install the hood again; i removed the rubber ...bumps? anyway there should be no problem w/ hood; well when i try to close it; it wont latch all the way. is this a common problem? also when i try to push down to see if i can get it to latch the headlights seem to be in the way a little; it seems like the latch hook is not long enough; this was a perfect fit on an oz; whats wrong here?
thanks; im in middle of install so anything you can say will help immediatly....
thanks again,
heath
Old Apr 7, 2005 | 02:58 PM
digdat's Avatar
which hood? IT or Accolade? I'm assuming its the short Evo7 hood and not one with a stock grill attached?
have you tried the steps on accolades website to fit a hood? maybe the bolts need to be loosened to fit it?
Kelspar's Avatar
ney its the import trenz one; same one Vicouz (sp?) has on his profile (b/c i bought it)
going to try to loosen bolts to see if i can get any difference; will check back in about 5
Old Apr 7, 2005 | 03:06 PM
Kelspar's Avatar
ok; had already taken the lower latch bolt off and bent the latch upward thinking it may have been bent from before; but no luck; also tryed losening the mount bolts; no luck either; any suggestions? it seems to bump into my right headlight.....i was also in two fron end collisions but i really have no damage other than cosmo to the old bumper & hood. HELP PLEASE!!!!!!! aAHHAHAHAHAHAHAA
Old Apr 7, 2005 | 03:14 PM
Kelspar's Avatar
bump (cant finish install till i get this fitment [running outta daylight!]) *prays* for an answer.
Old Apr 7, 2005 | 03:28 PM
Kid Lancer 7's Avatar
I have a problem with my cf hood.. and i know the answer too it. just dont wanna put it on untill my new rims arrive...(i refuse to let my car look half assed lol) ok... i know that for sure it closes all the way... i did a test fit with out the stock hinges/bolts and it closes.. i need to move the hood down, closer to the bumper, but the tightness of the stock hinges wont let me.
so if u have the same problem that i do then your gonna have to be willing to
make the stock holes (the ones that the 4 bolts go into) Oval shaped. You can do that with metal drill bits. This will give you more room to move your hood foward so it can close all the way! my good friend imajinmyfx had to do this to his cf hood and everything works and closes tight n secure!.... hope that helps you / gives more insight!
Old Apr 7, 2005 | 03:30 PM
Kelspar's Avatar
so just shave out the stock holes on the stock latches?
Old Apr 7, 2005 | 03:51 PM
u know the 4 bolts by the windshield?? make those 4 holes oval shaped with a drill
Old Apr 7, 2005 | 03:52 PM
yeah!! that gives you more room to play with... your hood should be able to close shut all the way
Old Apr 7, 2005 | 04:06 PM
Kelspar's Avatar
God i hope your right; im gona do it tomorrow when i have time; just have to drive slow until then.....
Old Apr 7, 2005 | 04:07 PM
yeah just PM imajinmyfx he's done it before
Old Apr 7, 2005 | 04:08 PM
if you can close your hood all the way with out the hood being bolted to the hinges by the windshield it will work
Victor Kasper
Nov 7, 2015 12:08 AM
Boostin_AWD
May 25, 2012 01:59 PM
Kelspar
Mar 21, 2005 12:05 PM
v8killer
Mar 3, 2005 07:04 PM
BensLancer
Lancer Troubleshooting
Aug 12, 2004 09:34 PM
