Catback installed, now weird idle sound?
Old May 10, 2005 | 01:42 PM
Slovak's Avatar
It's possible Danno, but I did notice that I stand corrected on something I said earlier. It does not do it from a cold start, like after sitting all night, just when the car is warmed up to normal operating temps.
Old May 11, 2005 | 06:08 AM
thursday448's Avatar
My idle is up when i have AC on with subs. I would say cooling fan
Old May 11, 2005 | 06:10 AM
Or turn all your extra's off, maybe it will go down
accumulationg $$$ for a turbo
Old May 11, 2005 | 08:11 AM
Danno's Avatar
Check your lower rad hose after you car has been sitting for a bit. If it is collapsed then that could be your problem. Go to the dealer and get the recall for the rad cap done.
Danno
Old May 11, 2005 | 03:41 PM
Slovak's Avatar
Recall? What recall? Where can I get a list of any and all recalls for my 05 Lancer,other than the dealer?
Old May 11, 2005 | 05:52 PM
i have to agree, i had a recall on my car, nothing about the idle, about steering, dealership took it, have it checked out by the dealership
Old May 11, 2005 | 05:55 PM
camaro379ss's Avatar
i didnt know there was a recall besides the fan controller unit thingy.
Old May 12, 2005 | 04:38 AM
oz4g94's Avatar
Originally Posted by Slovak
Yesterday I installed my Buschur catback, and all went well. Ever since then my car seems to idle up and down, but the rpm indicator doesn't move. Yes I reset the ECU too. It sort of sounds like when you tap the gas at idle you hear the humm of the magnaflow, except I'm not tapping the gas. The car never did this before the catback, and nothing under the hood was touched except disconnecting the negative battery terminal for 20 minutes or so, then reconnecting it and letting the car idle for another 20 minutes or so after the catback was installed. Any ideas? Car runs fune too while driving.
if you are still having the same problem, i know exactly what it is. when you disconnect the battery to reset the ecu, then your car will idle strange, once you drive for about 15 miles or so, it should start to idle normal again. i had the same problem when i had disconnected my battery to install my headers.
Old May 12, 2005 | 02:19 PM
Slovak's Avatar
Yeah, it seems to be idling ok now. Weird
OL_DIRTY
May 19, 2015 09:04 PM
HornstarBU
Mar 24, 2015 02:25 PM
EVIL_EV0
Sep 30, 2014 09:38 PM
superkizuna
Apr 28, 2014 09:43 PM
SW20Mike
Aug 24, 2011 05:40 PM
