OBD 2 interface cables
Old Aug 22, 2005 | 12:23 PM
blaze_125's Avatar
I've reading a bit on OBD interface cables and I don't seem to be able to find the answer I'm looking for... What are the main differences between the OBD 2 from a regular import car(like Mitsubishi and/or Honda) and the OBD 2 from a VW. Plenty of interfaces are available out there but most(if not all) say VW compatible
Just so you know, if you don't already... I puchased this cable and I'm wondering if I made a mistake
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
And for those who don't know... the interface cable is what allows your computer and/or Pda to interact with the obd2 port.
Old Aug 22, 2005 | 01:12 PM
Alchemist's Avatar
OBD-II is a standard so they're supposed to work on all cars that are OBD-II equipped (1996-2005, some 1995s and a few 1994s)
Old Aug 22, 2005 | 01:18 PM
blaze_125's Avatar
That's what I think too... but was looking forward to confirm
Old Aug 22, 2005 | 01:35 PM
XTXANDY's Avatar
I think it was that VW/Audi had like a different type of software or something, the obd-II port is the same. But i'm not going to garantee anything either. That is just what i had though.
Old Aug 22, 2005 | 03:14 PM
rhyzin's Avatar
^along those lines. for generic obdII, all manufacturers include iso pinouts for generic OBDII. other than that, there are two standards: iso and sae. most of the euro and asian cars happen to run iso and domestic cars run sae. i believe this is for manufacturer specific sensors and codes.
Old Aug 22, 2005 | 05:15 PM
alexandru's Avatar
There's actually 4 different OBD II standards, and rhyzin is right, ISO is used by most all imports, but I know that here in the US, there are 2 standards used by different companies ( don't remember which ones now ) So if you got an ISO one you should be ok
Old Aug 22, 2005 | 06:23 PM
Alchemist's Avatar
I stand corrected... shoulda known "standard" meant "well, kinda similar"
Old Aug 22, 2005 | 08:04 PM
rhyzin's Avatar
i am also standing corrected
Old Aug 22, 2005 | 08:16 PM
Z_Lancer_Man's Avatar
Interesting, so with this cable, you can hook up a PDA, and using some special software, you can monitor the car? That would be rather nice.
Old Aug 22, 2005 | 08:43 PM
alexandru's Avatar
heh, well, you'd need a serial port on your pda, or buy a compact flash card which has a serial port on it. Something really cool I saw, was this OBD II connector which had a bluetooth transmitter attached to it, and you got this compact flash bluetooth card and you could monitor the OBD II stuff wirelessly, from I think a max of 300 ft (100m) for class 1 bluetooth
I don't have the link for it anymore, but I remember the whole thing was upwards of $300.
Also, when I get some time I'll look through my bookmarks, I should have some OBD II info in there, check my other post about the Lancer ECU to see what I wanted to do
Old Aug 22, 2005 | 08:59 PM
4g94T's Avatar
yes they sell software that could monitor the car.
www.digimoto.com
Old Aug 22, 2005 | 09:45 PM
03RallyLancer's Avatar
also if you go to digimoto you can look up what kind obdII we have which is ISO according to them... but it lists for a lot of different cars and gives you the different outputs... i guess thats what you would call them.
Old Aug 23, 2005 | 06:31 AM
blaze_125's Avatar
Thanks guys... so hopefuly this cable will work.
These are the softwares I will try during the next 2 weeks:
Auterra
Digimoto
Vag-Com
ProScan
AutoEnginuity
Old Aug 24, 2005 | 06:30 AM
blaze_125's Avatar
Got my cable yesterday and tried a few softwares last night
Auterra > Seems to be working but I only have the Demo Version right now.
Digimoto > Does not Work so far
Vag-Com > Unable to read the Interface > Unable to connect to OBD2
ProScan > Haven't tried it yet
I kinda whish I never connected Auterra to the OBD port. I've got like 6 or 7 Trouble code stored in there
Old Aug 24, 2005 | 11:23 AM
rhyzin's Avatar
well, the demo software for the auterra is the same as the release software. if it's working with the cable, then great!
