Just got the NEW ///RRM Crank pulley installed!
Originally Posted by Z_Lancer_Man
Putting the car in 5th gear and standing on the break kept the crank from moving
Originally Posted by Blacksheepdj
That'd be "put it in park (P) & hold the brake" .
i tried 3 different airguns and none of them worked. then I took it to a friends house and he used a socket to hold my flywheel still and used a breaker bar on the pulley bolt. It came off fairly easy that way.
Originally Posted by mitsuman6
i tried that also. It didn't work for me and I have an AT.
oh dear....poor auto guys.
i guess those impacts that I tried weren't that good. And yes I wish I had a manual. I'm just glad I got it on without having to take it to a shope and pay. By the way ROCK I am completely satisfied with the pulley. It's a great product.
i found that rather than using a socket w/ the impact gun the crankshaft bolt that the gun will provide much more torque if you insert the 1/2inch tip of the gun straight into the crankshaft. it's pretty much common sense but figured i'd post it incase somebody else was unaware of that. by doing it that way the crank doesn't spin since the bolt is cracked imediately. otherwise , you will need to lock up the crank like mentioned earlier.
