Just got the NEW ///RRM Crank pulley installed!
Old Mar 3, 2006 | 08:59 AM
  #421
ROCK's Avatar
Heat is an old trick. It worked for him.
ROAD/RACE
Old Mar 3, 2006 | 09:15 AM
  #422
oz4g94's Avatar
ROCK do you keep them stocked or do you have them made upon request?
Old Mar 3, 2006 | 09:19 AM
  #423
ROCK's Avatar
We have 50 instock right now.
ROAD/RACE
Old Mar 3, 2006 | 10:38 AM
  #424
comatose721's Avatar
ROAD/RACE
i know heat is an old trick but this just seemed a little too dangerous to do in a garage full of combustible material.
Old Mar 7, 2006 | 08:03 PM
  #425
jchangsta2six's Avatar
i need help ... there is still noise coming from my belt ... its not all the time .. only sometimes ... i've loosen my belts ... and its still happening ... can it be that the pulley is to tight? i'll loosen it some more tomorrow morning ... but they are pretty loose ... thanks
Old Mar 7, 2006 | 09:25 PM
  #426
Z_Lancer_Man's Avatar
Do the belts start out squealing and then eventually go away? This is what happened with mine and it was because they weren't tight enough. What was happening was when the belts were cold, they were slipping, causing the squealing, but after they warmed up and got softer, they gripped better. I simply tightened them a little more and now no more squealing.
Old Mar 7, 2006 | 10:30 PM
  #427
ROCK's Avatar
There you go........ Straight from Z.
ROAD/RACE
Old Mar 8, 2006 | 11:48 AM
  #428
Thanks Z ... maybe they are to loose ... they do squeal within the first few mins, and then stop.
Old Mar 8, 2006 | 07:11 PM
  #429
ROCK's Avatar
See the Lancer Communtiy does help. Have not see "do a search" in a while.
ROAD/RACE
Old Mar 8, 2006 | 07:59 PM
  #430
lancerman360's Avatar
I am still happy with mine but the other day I had my a/c on (yes its hot in Texas already) and noticed that when the condenser came on the belt would squeak. I think its just loose. all I know is that RRM has made a @#!$ good product!
Old Mar 8, 2006 | 08:32 PM
  #431
joberk3's Avatar
how about if it stays squeaking while you drive?
Old Mar 8, 2006 | 08:36 PM
  #432
05ES's Avatar
then i would suggest that your belt is really loose or you need some oil my friend (in the case of it not being the belt).
Old Mar 8, 2006 | 08:37 PM
  #433
They may still be loose, so loose that even warmed up they are loose. Unless they already feel very tight on there (lots of resistence when you push on them), try tightening them up some more.
Old Mar 9, 2006 | 04:33 AM
  #434
if it's over tightened, the outer bearing in the generator housing will start to race/squeel. if it's too tight make sure you relieve the tension ASAP. otherwise follow up on what Z Lancer said.
Old Mar 11, 2006 | 10:11 AM
  #435
primo16's Avatar
Good work rrm. my first 2 gears on my AT go by considerably faster, well worth the $100. ive narrowed it down and the biggest gains ive felt are from 45-60, the place where my car was lacking the most i felt. If you dont have one of these order one its certainly worth it!
