Just got the NEW ///RRM Crank pulley installed!
Old Apr 10, 2006 | 04:09 PM
  #526
02OZR's Avatar
All this “love” for Rock(RRM?) is starting to remind me of a gay **** I watched once........ (the girls never came... THE GIRLS NEVER CAME!!) lol
Old Apr 10, 2006 | 04:18 PM
  #527
Melaz425's Avatar
I cant see how this could be good because the stock pulley is balanced for your stock redline. I can understand if you have a ems and are reving to 8k rpms then i could understand.. but I would just leave it alone.
Old Apr 10, 2006 | 09:00 PM
  #528
ROCK's Avatar
Pullies yea, gay **** never
ROAD/RACE
Old Apr 18, 2006 | 11:25 AM
  #529
primo16's Avatar
So heres to all who installed the pulley. be careful.
i guess while it was off i bumped something with a wrench, and it caused my timing belt to eventually snap off i dont understand how but...
Now i have $400 in towing
PLUS i need a new...
Crank
Crank sensor
Timing Belt
Valve's
2 Pistons
2 connecting rods
A new cam
and 1000+ in labor
Old Apr 18, 2006 | 11:28 AM
  #530
travelsize420's Avatar
wow! that sucks man. what the hell did you nudge?
Old Apr 18, 2006 | 12:08 PM
  #531
ROCK's Avatar
Crank
Crank sensor
Timing Belt
Valve's
2 Pistons
2 connecting rods
A new cam
and 1000+ in labor
That sucks but it is fairly impossible that they are related. I think it was just time for a timing belt maybe.
ROAD/RACE
Old Apr 18, 2006 | 04:16 PM
  #532
drucea's Avatar
hmmmm i wonder how much the pistons and cam will cost...check the price and see if its anywhere near the rpw cams and RRM pistons, get some good stuff while your at it. Sorry to hear about it though.
Old Apr 18, 2006 | 05:16 PM
  #533
oz4g94's Avatar
Crank
Crank sensor
Timing Belt
Valve's
2 Pistons
2 connecting rods
A new cam
and 1000+ in labor
how many miles are on your car now? its not that likely that could have happened unless the belt was nearing its end.
Old May 20, 2006 | 01:07 PM
  #534
saecoes's Avatar
Does anybody know a good way to remove the crank pulley on an AUTO w/o an impact gun. All i have is a ginormous breaker bar with a 1/2" drive that fits in the nut of the of stock pulley. I have tried placing the car in 1st and stepping on the breaks, and the crank pulley still moves. I have tried a screwdriver through the pulley but there is too much play. What can do to stop the crank from spinning on my auto. Help from auto guys with experience with the pulley will be most helpful. Thanks in advance
Old May 20, 2006 | 01:16 PM
  #535
lancerman360's Avatar
There is really no way to stop it. when I put mine on I had no luck. I tried several times over a couple of weeks with no success. I eventually had to take it to a shop to use their air gun. with the impact wrench the pulley didnt move at all. I would recomend letting someone with a very powerful ari gun take it off. 120psi didnt work for me.
Old May 20, 2006 | 01:21 PM
  #536
rhyzin's Avatar
pop open the flywheel cover from under the tranny and have someone hold a large screwdriver to one of the flywheel teeth. that'll get it to stop moving.
someone else recommended putting the car in fifth and stepping on the brakes.
Old May 20, 2006 | 01:32 PM
  #537
putting the car in 5th does not work on an auto. the screwdriver thing sounds like too much work and not very safe, when you can just get a shop to do it for $50.
Old May 20, 2006 | 02:09 PM
  #538
rhyzin's Avatar
oh yeah, auto.
the screwdriver thing is easy. two bolts from under takes off the cover. fit a screwdriver in a tooth and hold against the edge of the opening. i've done this on a bunch of cars to change the timing belt. but if you have $50 to blow, go ahead.
Old May 20, 2006 | 02:19 PM
  #539
I have just never heard of doing that before and sometimes I am just lazy.
Old May 21, 2006 | 10:06 AM
  #540
ROCK's Avatar
I would really love to see you use an impact instead of possible damage by using screwdrivers, plywood, a light bulb and prostitutes. Pay someone or buddy up to person with impact gun.
ROAD/RACE
