Just got the NEW ///RRM Crank pulley installed!
yeah its not hard to do yourself. i just have no tools at college and am anxious to get it done without having to wait 2 weeks. but i told them it should only take an hour or 2 and the guy said "then it is going to be at least between $80-$120" so I figured screw it, thats more than the part itself. so I'm getting it done this weekend at home for free. you might want to get your own quotes from where you live cause i'm sure they will vary greatly.
i'm hoping to install mine after my final today. under the car with my right hand holding a screwdriver on the flywheel and my left hand with a torque wrench on the pulley bolt. yay.
Originally Posted by rhyzin
yeah, the crank. and you don't want to turn the crank in the counter-clockwise direction(i think, i'd have to check again). that's a no-no.
i believe it messes with the timing if you do so. not sure though.
Originally Posted by drucea
ok, thanks, i forgot to ask about that...any good ways to keep it in place?
RRM recommends an air gun. dunno how many of you got one of those. what i personally have done is prop one of the spokes of the pulley with an "L" tire iron or similar. i dunno how the aluminum pulley will take to that method so i'll only recommend it for taking the stock pulley off. for putting the pulley on, i would jam one of the spokes of the flywheel through the small plate under the transmission with a screwdriver of sorts. or maybe just the teeth. whichever.
if anyone has any objections, please post. maybe you'll get me to stop my retarded ways
clever idea. it should work to get the pulley off.
when you install your new one, if you intend on using the same method as the removal, i would recommend some sort of padding between the bar and the pulley. (maybe if you splice a larger diameter vacuum line and put it around the bar)
i would just hate to see the pulley get bent, chipped, etc. rotating objects that aren't balanced properly tend to get a little excited.
good luck with your method
let us know how it works.
impetus19 - there are timing marks. Check them.
I know Subaru ain't Mitsu, but when I did mine, the instructions said to put the car in 5th and stand on the brake. I don't know what it does, but I did it...
Originally Posted by impetus19
Is there any way to tell if the crank got turned???
