converting that little cubby hole thing to a radio holder
Old Aug 13, 2006 | 03:00 AM
brian38662's Avatar
Originally Posted by newbiewonkenobe
what about the wiring to your radios? Did you need to extend the wiring/buy a wiring harness? I'm getting ready to do this same thing, for placing guages where the radio sits. Thanks for the great thread!
No, Actually the wiring harness reached the bottom cubby with no problem. I was worried it wouldn't reach either, but everything hooked up without any extensions. Good luck!
Old Aug 13, 2006 | 06:05 AM
03lancOZ's Avatar
Yea I just put mine in yesterday, and it took me like 5 minutes... That easy....
Old Aug 13, 2006 | 06:42 AM
newbiewonkenobe's Avatar
you guyz rock! Thanks for saving me the headache of getting an extension harness!
Old Aug 13, 2006 | 08:55 AM
LancerAdam's Avatar
The wires come from the bottom. So there is more than enough room. sells a blank plate to cover the hole till you get your guages.
Old Aug 18, 2006 | 04:45 AM
is there a how-to on removing the middle piece which holds stock radio in, you know the piece that covers the hvac controls, etc?
Old Aug 18, 2006 | 06:11 AM
mscc04's Avatar
Pull on the climate control knobs towards you....they should pull out. There are two screws...one behind two of the knobs (use a philips screwdriver). Then pull on the panel towards you. This may take a little force but be careful not to break it. This is how you do it on a 02-03 model...i'm not positive if the interior is similar for the 04+ models. Good luck
Old Aug 18, 2006 | 06:56 AM
LancerAdam's Avatar
I use a butter knife between the panell and dash, pry all the way around then it pops right out. It is the same for the 06 did one last week for a friend. To remove the little cubby hole there are 2 philip screws in the top of the cubby hole a short screw driver will make it the easiest to get it out. Take thoes screws and pull... you will be amazed at how easy this is. As for the radio, there are 4 screws holding it in. take thoes out pull the radio forward and disconnect it from the harnes pass the harness down to the new opening and reconect it. Dont forget about the antenna (its the small round cable in the back)
Old Aug 22, 2006 | 05:03 PM
BEANIE's Avatar
so the radio relocator from 500whp.com is that one good for the 2002 lancer es model i am not sure please help...
Old Aug 22, 2006 | 05:37 PM
LancerAdam's Avatar
just go to your dealer and ask them.
Old Aug 22, 2006 | 07:33 PM
BEANIE's Avatar
cool not a problem thats the one you all were talking about that was 30 bucks or somehting like that right. dealership here i come...
Old Sep 8, 2006 | 10:39 PM
evo_shibby's Avatar
i'll be have my avic n2 installed to the bottom with the relocator. i hope it'll fit and i'll have clearance. my friend said he'd get me spacers since it needs to be pushed forward a bit.
does anyone know if anyone has successfully run this set up and had no problems with the screen coming out?
Old Sep 10, 2006 | 05:17 PM
evo_shibby's Avatar
Originally Posted by brian38662
It works perfectly fine, I bought mine because I wanted the gauges in the dash. Take 30 minutes to install. The only difficult part of installation is popping out the clips which hold the center peice of the dash together through the glove box, once this is done remove the cd payer and everything is EASY! Remove two screws from stock cubby hole, and install the damn relocation kit. Have fun!
hey nice gauges, i got those too.
how does your boost gauge light up? mine doesnt light up as bright compared to the other 2, im think this is because the other 2 have bigger numbers while the boost gauge has smaller and more numbers.
smokey
May 8, 2015 01:39 PM
SubtleStyle
Outlander Sport
Feb 28, 2013 07:07 AM
Luke18
Jun 7, 2010 09:35 AM
ski10804life
36
Jun 27, 2006 05:54 PM
KILTERMAN
May 29, 2004 07:53 PM
