Help Please Warm-up Cat Problems.
Old Oct 18, 2006 | 08:51 PM
  #31
superfly78209's Avatar
Basically the recall for the cat was a pcm flash b/c the cat was getting too hot after stop and go/ flooring the car. Well now I have permanent damage to it and it's not filtering out the bad exhaust like it's supposed to. It still flows fine so I really don't care that it's broken just as long as I can keep my check engine light off so when there's actually an engine problem I'll get a new light instead of the existing light covering things up. Plus it's kinda annoying to have that light on all the time.
Old Oct 18, 2006 | 09:03 PM
  #32
ambystom01's Avatar
Yes everyone does start out as a noob, but the general understanding is that noobs won't be lippy to people who are actually trying to help. If you listened rather than simply posting and posting I wouldn't get all pissed off. You have been given your answer like 8 times now. Putting on a CEL eliminator will not solve your problem, if you move the first oxygen sensor out you will get the same code or possibly a new code, I know this from experience. Get the code pulled and see what it is, simply coming on here and saying "my car has a code, will this fix it?" is not all that useful.
Old Oct 18, 2006 | 09:19 PM
  #33
Higgity Hank's Avatar
If you're so damned annoyed with the light, and don't want to take good advice, here's some cheap advice. Take apart the dash, and rip out the bulb. Problem solved. Now take the money you've saved, chalk the whole thing up to a weight savings and enjoy your new, more powerful lancer.
Old Oct 18, 2006 | 09:33 PM
  #34
Blacksheepdj's Avatar
Superfly strikes again - I want advice, but I won't listen to it!
I'm getting complaints, so thread is closed.
Jared Murphy
11
May 15, 2017 08:45 PM
Boombox
32
Jan 23, 2016 02:34 AM
nothere
Feb 10, 2010 06:25 PM
troe666
10
Sep 5, 2006 01:01 AM
meewantevo
Lancer Engine Tech
13
Dec 29, 2005 07:20 AM
