View Poll Results: What should be made after the damper?
Downpipe
10
19.23%
Rear Disc Brake Conversion
21
40.38%
Projectors
21
40.38%
Voters: 52. You may not vote on this poll
New Products for the Lancer!!!
Old Dec 4, 2006 | 03:33 PM
  #46
drucea's Avatar
This is the A2 header.
This is the OBX header + DP.
The A2 one meets into one much farther down than OBX, but OBX supplies a DP with their header. But those are both 4-2-1 designs, a mix between shortys and long tube 4-1 designs. Can't say which is better. But I think if they made a DP, they should make a header to go with it. The RRM and stock header could utilize the same DP since they meet in the same place, and I think if someone got the A2 header, they couldt just get the rest custom done since it already goes down under the engine.
Old Dec 4, 2006 | 03:39 PM
  #47
drucea's Avatar
ok, i guess i can't link anything from the A2 site, but anyways, the A2 header is like the OBX, but without the second pipe, and the pipes are in a different order.
Old Dec 4, 2006 | 03:44 PM
  #48
03lancOZ's Avatar
Yea, it is sorta like it, but I do not know if the pic is for a header for the lancer... It would require another downpipe just to meet to the cat... Does anyone know anyone that has the A2 one?...
  #49
MurphDurph's Avatar
not to break the chain about DP and headers, but id like to see more bodykit designs for lancers. also, id like to see a front mount cold air intake on one.
Old Dec 4, 2006 | 03:48 PM
  #50
03lancOZ's Avatar
Making bodykits are a bit more involved then we can handle right now... But who knows, maybe this will pick up and I can do this full time...
Now the front mount cold air intake shouldnt be a problem at all...
Old Dec 4, 2006 | 03:49 PM
  #51
03lancOZ's Avatar
does anyone know where I can find blank header flanges for the lancer?... Have been looking around for a bit and nothing... thanks in advance...
Old Dec 4, 2006 | 04:23 PM
  #52
Wallesasuaz's Avatar
+1 on new body kits for the lancer.... Atleast something that resembles the CEdia bumper from japan. If someone can come up w/ a duplicate/clone of that, it would be sweeter than having to pay mad money for a true JDM piece.
Old Dec 4, 2006 | 04:34 PM
  #53
SLVROZ_03's Avatar
Here's another idea. If possible, make a bracket to fit the stock Evo Brembos onto our Lancers.
Old Dec 4, 2006 | 04:35 PM
  #54
dewood*'s Avatar
I cant find many good headers, exhausts, headlights
I think we can use some good stuff that don't come from Evos.
Old Dec 4, 2006 | 04:37 PM
  #55
djblinx's Avatar
Originally Posted by 03lancOZ
Nothing against 04-06, but myself and my friend have the 02-03 lancer, if anything we would go the route of something compatible to every model, but if I had to choose it would be the 02-03... But who know after a bit, maybe once of us may upgrade...
that's kool, but i think you guys could get alot of money from us 04-06 models. We would like to see stuff that's only available for 02-03, to be available for our lancers. I know I would be buy stuff.
how about some interior stuff also, not sure exactly what would be good, but mabye some other ppl have suggestions.
Old Dec 4, 2006 | 04:39 PM
  #56
03lancOZ's Avatar
Well we right now are going to go with the damper and rear brake conversion, it's only 4 of us, so better if we take it one step at a time... The damper shouldnt be hard at all, just time involved with making the mounts and all... Have already contacted Ingalls and will be using their dampers, same one on the EVOs...
And looking at rear brakes from an eclipse tomorrow, so should have an idea on that soon... Just figured I would go with some easy things first to get things going, and then get more in depth...
Old Dec 4, 2006 | 04:40 PM
  #57
03lancOZ's Avatar
Well I am trying to do stuff that is compatible with both generations, just don't have an 04+ to use... But I do know someone a little bit from me that I am sure would be willing to help...
Old Dec 4, 2006 | 04:53 PM
  #58
djblinx's Avatar
sweet, w/e's good for you guys, im was just making a suggestion. Also if you guys don't mind, i have no idea what an engine damper does, lol. Not to go off topic but could someone explain real quick. Thkx!
How about a replacement automatic shifter that looks good and isn't crapy like the ones out there?
Old Dec 4, 2006 | 04:56 PM
  #59
03lancOZ's Avatar
Here is info right from Ingalls' site
http://www.ingallseng.com/parts/ETD/ETD-Specs.htm
Old Dec 4, 2006 | 05:04 PM
  #60
mtags24's Avatar
how about a bolt up cat-back that is not 450+ dollars but still uses a good muffler
