HID kit off Ebay hmmmm???
Old May 14, 2007 | 10:54 PM
  #76
DarkMastyr's Avatar
Just f.y.i. All factory systems (ALL) use 4300k bulbs for maximum lumens output. If you *think* BMW's, Audi's, Mercs are blue/purple, it's because the colorband at the cutoff shield of their projectors is causing a slight distortion in the color. Some older cars with HIDs project a blue/purplish because their bulbs have colorshifted to higher temperatures. So there's your baseline in terms of color/performance.
Aftermarket HID kits do not have a standard gauge of temperature. What one vendor calls 6000k, another vendor may call 8000k. So keep that in mind.
Old May 15, 2007 | 05:44 PM
  #77
jRox's Avatar
^^ very true.
Old May 17, 2007 | 09:01 PM
  #78
army685's Avatar
Where did you buy the kit from??? and how did you install it
Originally Posted by Gambitincognito
hey I just installed the HID's myself and I have a few questions/problems:
1. they only work when I turn on the high beams
2. when I stop the car at a stop light it shakes and sounds like its gonna die, the rpms go below 1000 as well but manages to not die.
did I do something wrong? or how can I help this?
Old May 18, 2007 | 12:53 PM
  #79
sadude's Avatar
If the lights only turn on when you click the high beams it means you tapped the wrong wire...since our cars have a 9007 bulb, that has both high and low, you need top the low beam wire.
The ground/3rd wire will not change, its the hot wire you have to change
Not sure about your other problem unless somehow it's connected to the bad wiring job...it's possible you moved something else when you were mounting it
double check your work or worst comes to worst just unplug the whole kit, and try your car then
Old May 18, 2007 | 12:54 PM
  #80
sharkm87's Avatar
i bought a few kits off ebay..all are great..
Old May 22, 2007 | 09:40 PM
  #81
aznwidnolimit's Avatar
well 8000k is goin to be more of purple than blue... my car is white and im planing to get 6000k on it... its kinda white but has a touch of blue in it... here is a link that has HID for cheap
http://www.xenoneyes.com/index.php?page=hidkits
Old May 23, 2007 | 03:54 PM
  #82
army685's Avatar
When I installed my HID KIt I lost my high beams all i have is low beam but its so bright and clear I realy dont need the high beams I contacted the company and they told me that I would loose the High beams
Old May 23, 2007 | 04:08 PM
  #83
KFive's Avatar
Originally Posted by Achilles
I thought the 03s was the only year to come with HIDs standard then after became an option. One of my buddies has a 03 GSR with no SSL but still has OEM HIDs and no he didnt put them in after he bought the car.
Yes, all the 03's came with the Hid's
Old May 25, 2007 | 07:57 PM
  #84
Gambitincognito's Avatar
well its been a couple weeks since I have installed my HID's and I notice that the passenger side lights look whiter than the driver side lights. Does anyone else have this problem? Why does it do this?
Old Mar 14, 2008 | 07:05 PM
  #85
diegoalunan's Avatar
bought one on eay.. one side (bulb) lasted 8months.. i was gonna warranty it.. ut dint have the time and needed mylights asap.. ended up buying another kit off a local store..
i was happywith my ebay kit it was just that i prolly got a bad left side set..
Old Mar 26, 2008 | 07:21 AM
  #86
spydersinh's Avatar
So I'm new to the HIDs. I've been browsing on Ebay and found many different kits costing anywhere from $30 to $120 before shipping. Does it really matter because all of the kits look like they come with the same equipment?
kyoo
Apr 17, 2014 06:29 AM
EvoX_BV01
Dec 12, 2011 10:57 PM
Ballamouse698
Jun 5, 2010 05:06 PM
lanceritis
Feb 11, 2010 10:36 AM
TheShortBus
Dec 6, 2008 02:11 PM
