2002 lancer front end whinning
Old Apr 20, 2007 | 02:13 PM
tattoo1981's Avatar
Question 2002 lancer front end whinning
Have a 2002 lancer there is a whinning coming from the front end not sure what it is. There is no shake or shimmy. The faster you travel the faster the sound. Also not coming from the engine. Thank you in advance
Old Apr 20, 2007 | 06:29 PM
04lancerEsGuy's Avatar
If it's not the engine than there could be two possibilities:
(1) You are hearing things
(2) Suspension
Be more descriptive.....
Old Apr 20, 2007 | 09:05 PM
Walkingchaos's Avatar
sounds like wind movement through something.
Old Apr 20, 2007 | 10:43 PM
Evo_Jr's Avatar
+1. When your doing mach 1, sounds start coming from the front.
It just depends on what kind of sound. Could be a pulley, suspension, just pretty much anything.
Old Apr 20, 2007 | 10:58 PM
Kid Lancer 7's Avatar
i say the plastic roof in front of your springs (part of the wheel well)...
is this a hissing (air)sound or more like a grinding (think a poker/spades card in a bicycle spoke to make a moped or Civic fart can sound )
if its grinding... make sure ur front wheel well isnt loose... especialy if u werent the original owner and it was body kitted. i had this isssue.. and i was driving to miami to orlando and i heard a buzzing sound @65MPH+ it Phucked my tire upp!! bald as a porno chicks beaver!
Old Apr 21, 2007 | 01:06 AM
kungfugirl's Avatar
remove squirell
Old Apr 21, 2007 | 06:29 PM
SLVROZ_03's Avatar
^No, it's more like remove wife! LOL
Old Apr 21, 2007 | 06:54 PM
lncrphish's Avatar
yeah, had the same problem when i go over 35mph. lol
Old Apr 25, 2007 | 02:25 PM
tattoo1981's Avatar
it happens at most any speed. Sounds like the prop on a small plane. it sounds very uniform the speed seems to increase the speed of the sound, not the sound level of it like the wind passing through anything. thanks again in advance
Old Apr 25, 2007 | 02:32 PM
crypto's Avatar
Former Vendor
have you actually looked to see if there is anything loose/stuck/wrong etc?
take your wheel off and poke your head around, see if you can find anything.
also check the tightness of all the nuts and bolts holding everything together. suspension, belts, lug nuts etc.
Old Apr 25, 2007 | 07:47 PM
excessforce's Avatar
did you check and see if its your wheel bareing? i just had to replace one on mine...
Old Apr 25, 2007 | 11:03 PM
Majuljo's Avatar
check your breaks!!!
Old Apr 26, 2007 | 08:15 PM
djblinx's Avatar
it could just be the engine knocking.
Old Apr 29, 2007 | 12:44 PM
tattoo1981's Avatar
if it is the engine why would it be happening even when i'm not pressing the accelerator? I also thought about the rotors but there is no shake even when the brakes are applied.
Brandisher
Nov 24, 2015 01:19 PM
limmartin
Oct 14, 2013 06:37 PM
Javito813
Apr 4, 2012 04:02 PM
Robert_K
Aug 19, 2005 09:49 PM
superman105
71
Jul 13, 2005 09:42 PM
