ROAD/RACE-2008 Lancer HIDs
90% would probably say no. But if you happen to go to a dealership with a cool service manager, they might give it a shot. This type of thing just comes down to chance and luck. You'd be asking them to tamper with parts of your car that are normally considered "safety items."
It would be worth a shot if the DRL's could be rerouted to the fogs. I think the 2007 Outlander has its DRL's through the fogs, and thus making it a lot easier to install HID's on lows. Its a shame all Lancer models dont come with fogs as standard
instead of rerouting the DRL's...just unplug the whole oem headlight harness and buy a relay and splice the plug that usually plugs back into the oem harness to the parking lights.....baddabing....no DRL's...very cheap to do and easy.
Idrew this up real quick the other day....I hope I didn't miss anything and it helps u out a little.. go to mobileHID.com and they have pictures of the relay to help u more understand the whole setup
the yellow light on the side of ur headlights will be ur drl.. and when u switch ur lights to night lights then ur hids will kick in..i think
Ok yeah that makes sense. What about in the middle position between off and full headlights? The position which brings on your dash lights and taillights. Would the HID's come on then too or only come on at the headlight on position?
Yeah I only use the middle position in evenings when you dont need any headlights,but still want the dashboard lights. Although I imagine the HID's wouldnt come on in that position. Since the full voltage doesnt get sent to the headlights in the middle position anyway.
Well in theory this seems like a pretty good solution so far. chetman7 is this how you have yours running? And are there any issues with this you've come across?
