The Ultimate Milage and Gas Milage Thread!
Old Oct 17, 2007 | 05:38 AM
  #526
MurphDurph's Avatar
02 OZ w/ 101k
Old Oct 17, 2007 | 05:42 AM
  #527
GTS_rider's Avatar
08/ 13.5kmiles!
edit: I also have a 97 mirage.. with 164k miles.. runs fine.. only problem it has right now.. is the wipers (motor) don't work well. need to check on that over the weekend..
Old Oct 17, 2007 | 05:45 AM
  #528
iyi0521's Avatar
'02 OZ 5 speed w/ 55k
Boosted for 5k
No problems
Old Oct 17, 2007 | 08:25 AM
  #529
Punkskalar's Avatar
I work on a guys 04 ES all the time...
He's a pizza delivery guy, bought it in late 04...
130,000 miles....
Repairs so far:
Both front Wheel bearings (dealer only item, trust me on that)
3-4 Sets of front rotors and pads
I flush the Automatic tranny everytime I get near his car, its black fluid every 20K easily
Full set of rear brakes including drums
I did his first timing belt with water pump and all seals at 70K
Had to replace both front swaybar endlinks
Needed passenger side drive axle (also dealer only)
He has driven this car non-stop... No Mods, just a stock ES... Im waiting for the tranny to go out, ive never seen an auto eat fluid the way his does... The front wheel bearings went out at 90K, and they were a huge PITA to replace as well... Not a well built car in my opinion... He has more clunks and rattles than my Gutted 86 CRX track car did...
Old Oct 17, 2007 | 08:41 AM
  #530
crypto's Avatar
Former Vendor
2003 - 82k
Old Oct 17, 2007 | 08:44 AM
  #531
Lumpy's Avatar
03 ES with 103,000miles. The only major cost for me was the suspension. My stock struts started going one at a time at 90k, so I went coilover. While I was at it, I had all stock mounts replaced with new OEM units. Coilovers+mounts+install= about $1500. I can't really complain about the upkeep. I only feed it Royal Purple since about 50k miles, Castrol GTX before that, with PureOne filters. It's had the tranny flushed once, last year. I bought a full case of Mitsubishi fluid to flush it again soon this year because of that sticking problem when it's warming up. I had the timing belt changed at 60k. Like I said, I can't complain. It even let's me know when the battery will soon be ready to change.
Old Oct 17, 2007 | 08:56 AM
  #532
sgand's Avatar
03 w/ 53k.
The odometer says 5k, does that count?
Old Oct 17, 2007 | 09:51 AM
  #533
bahamut's Avatar
Originally Posted by wazzupbe1
If you have an auto, does your tranny sometimes stick between two gears and then suddenly jump. I guess thats the only problem i have.
Did you ever change your tranny fluid? or manually shift your auto tranny?
Old Oct 17, 2007 | 10:43 AM
  #534
trufleshufle13's Avatar
2003 at 43k no problems yet.. has ne one had a timing belt break before 60k
Old Oct 17, 2007 | 10:52 AM
  #535
Blacksheepdj's Avatar
2008, 9k
Old Oct 17, 2007 | 11:42 AM
  #536
SLVROZ_03's Avatar
'03 OZ Rally auto - 85k w/ all belts replaced, end links, rotors/pads (need rears NOW!), struts (have one yet to get), and a tranny flush. Only problems have been the Crankshaft Position Sensor (TSB item) - cleaned that area during the T-belt install & now an odd P to R grind/knock/noise while shifting with the breaks on (duh, cannot shift w/o the brake down).
Old Oct 17, 2007 | 12:12 PM
  #537
lancer2show's Avatar
you need a tranny flush
Old Oct 17, 2007 | 12:13 PM
  #538
05 lancer
im at 41k miles the only prob i had before was being slow
Old Oct 17, 2007 | 01:15 PM
  #539
iyi0521's Avatar
I had a problem eating batteries. Found out it was a operator error. Wasnt driving enough in the winter to let the battery charge properly. Oh and the reverse switch in the tranny went.
Old Oct 17, 2007 | 01:37 PM
  #540
mitsuozboi's Avatar
2003 OZ. Just hit 40k....
