Removing Evo spoiler need help
Hello Evom people. im removing the evo wing on my car. need to know what i can plug the holes with? need info how to remove the evo wing too. thank you
remove the plugs underneath the truck and take out bolts. If i remember 2 on each side. The Spoiler has 2-way tape on it. You will have to pry it off. It does come off. Don't mess up your paint though. When i removed mine i had rust. Apparently mitsubishi put more primer and paint on this damn spoiler than the rest of the car. I am a autoglass installer so I just plugged the top of the hole with urathane. (stuff that holds windshields in) Havent had a problem other than to save money and get my spoiler re-cleared!
2 you screw in 10mm and the other 2 is like a 10mm nut i think. its basicly 4 if u think about it plus theirs some weather striping around the base of the side posts that sticky
