RRM Piggy Back ECU install (Auto)
Old Jun 24, 2005 | 11:16 AM
  #61
Kid Lancer 7's Avatar
dammm was that with a piggy back?? how long u been usin that nos??
Old Jun 24, 2005 | 08:25 PM
  #62
mitsulancerrace's Avatar
NOS been in the car for 6+/- months n it was just NOS 50shot spray
Old Aug 12, 2005 | 05:47 PM
  #63
RobertK's Avatar
cleaned and re-opened.
keep installs to installs or I will be throwing out bans.
and bans don't care if your guru, vendor, or whatever.
sorry for this convience.
Old Aug 12, 2005 | 06:38 PM
  #64
RobertK's Avatar
for approx 4 years now, evom has had a Private Message System.
please use it if you want to talk to someone.
Old Nov 7, 2005 | 08:27 PM
  #65
this the same for the V.2?
Old Nov 11, 2005 | 11:23 AM
  #66
bump???
Old Nov 12, 2005 | 08:17 AM
  #67
comatose721's Avatar
doesn't the V.2 eliminate the vacuum line? just call Gabe or Rob at RRM. they're pretty helpful...not to mention friendly hahha...really, just call RRM, they'd be able to give you a direct answer much quicker.
Old Nov 12, 2005 | 08:39 AM
  #68
ROCK's Avatar
We are open 10-3 today PAC time.
ROAD/RACE
Old Nov 12, 2005 | 07:55 PM
  #69
i knew that, but i was only wondering if the wireing was the same
Old Jul 13, 2008 | 08:04 PM
  #70
njleeson's Avatar
im really confused about number 11 on v2 can anyone help?
Old Jul 13, 2008 | 08:39 PM
  #71
Green_Bandit's Avatar
Quite easy my friend!
10) Cut the WHITE/RED wire on ECU pin 65. (Leave enough wire on both side so that you can reconnect to both sides)
11) Connect the Piggy Back’s GREEN wire to the side of the cut wire that leads away from the ECU.
12) Connect the Piggy Back’s VIOLET wire to the side of the cut wire that leads to the ECU.
That Red/White you cut...
Take the piggy's green wire and solder it to the end leading into the car. (Under your dash)
The other end of that Red/White cable...
Take the piggy's violet wire you cut and solder that wire to the end that is leading back to the harness(Not the thing you unplugged it from but the thing doing the plugging) The gray piece
Nothing major will happen if you get em reversed. Your car will get bad gas mileage and stutter.
Old Jul 14, 2008 | 06:12 PM
  #72
ROCK's Avatar
THanks. IF you are stuck on install you can always call in for TECH. We actually have Tech support too! One of the few that does.
ROAD/RACE
Old Dec 12, 2009 | 03:03 PM
  #73
andymilonkis453's Avatar
is this installation for version 2?
Old Feb 28, 2018 | 08:24 PM
  #74
K.shedeed's Avatar
Urgent please
[QUOTE=Shingen;1302280]What is the install process for the Manual?
Fox[/QUOTE
ineed rrm wiring for manual transmition
thanks
Old Mar 6, 2018 | 09:26 AM
  #75
OZR_Lancer's Avatar
nice way to bump a 8 year old thread... why not just send a pm to rrm or call them lol
LeXcite
Jan 17, 2022 08:05 PM
llDemonll
Sep 22, 2021 05:43 PM
deeman101
Mar 3, 2021 07:56 AM
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
