Lancer OZ 0 to 60mph?
Old Oct 12, 2002 | 04:28 AM
  #46
zlancer's Avatar
you don't have to send your motor out. all you have to do is send J&E your motor specs and they can make you the pistons just by the dimensions. look at their website.
Old Oct 12, 2002 | 06:08 AM
  #47
Pimpson's Avatar
yes I think 4 grand would be worth it to have 20psi potential.
Old Oct 12, 2002 | 06:35 AM
  #48
cupOZnj's Avatar
i agree with yannotmi. there's more than just putting a turbo on to making your car perform well.
and to those that took off the rev limiter to get to 65 in second....you know you're actually LOSING hp after 5500 rpm right? the answer to an extra shift isn't increasing the redline (which will do horrible damage to your car since it's not made for that), it's to re-gear the transmission ratios so that you can wind out second longer....but that's a lot more work and money. there's just some things you can't easily fix about a car. i'm willing to bet that if i go through 3 gears to get to 60 and you go through 2, with stock ratios, i will win (as long as my power shifts are smooth )
Old Oct 12, 2002 | 07:56 AM
  #49
yellow_lancer's Avatar
zlancer... for real?? you just need to send them the dimensions?? damn... why would my cousin be lying to me... i dont understand... but yeah im willing to spend that much... to buff up my motor... then imma get like a big phat turbo... can u give me more info on that website thing?
Old Oct 12, 2002 | 08:00 AM
  #50
astondg's Avatar
Now I've read this I feel even worse. We just ran our 1991 Galant VR-4 with a GTech and the 0-100 time was 8.83sec, I posted about it here https://www.evolutionm.net/forums/sh...&threadid=9130 but now I've read that the stock OZ lancer does under 9sec I feel real bad. I'm not saying your cars are slow, but the Galant has the 2000cc turbo like the EVO.
Aston
Old Oct 12, 2002 | 08:35 AM
  #51
zlancer's Avatar
http://www.jepistons.com/pdf/customp...-orderform.pdf
there is the order form
Old Oct 12, 2002 | 08:36 AM
  #52
thanks a lot z.... really appreciate the help.... good looking out
Old Oct 12, 2002 | 10:05 AM
  #53
bahamut's Avatar
In manual format, you cannot hang 65 mph to last redline. In auto, yes. Gear ratios with only 4 gears.
The US spec galant runs the detuned 4g63T.
If you're thinking about the 6g72 3.0L from the 3K GT VR4 or the 6g74 3.5L from the Diamante. Forget it. No room, unless cutting out the firewall. Also, there is no way you can stuff 2 turbos in your engine bay.
Also, the last time I have checked the 3K GT VR4 is at least 5 inches wider than the mirage (just the overall width of the axle). Adj accordingly since the lancer should be about the same width as the 5g mirage.
People should go to the dealership and check out the 3g eclipse GT which has 6g72 motor w/o the TC. That motor itself is huge!
Old Oct 15, 2002 | 01:50 PM
  #54
YouNVthis's Avatar
lancers 0-60 is 9s...trust me...i know..experience
Old Apr 30, 2004 | 08:14 PM
  #55
NEPA03ES's Avatar
It would be easier to take the engine from your IROC, hook it up to a Cadillac tranny and stuff it in the trunk of the lancer.
Old May 1, 2004 | 09:20 PM
  #56
LancerEvoMR's Avatar
2 year old thread. Great job. Closed.
Kami_guru
Lancer Tranny/Drivetrain Tech
Jul 14, 2017 12:32 PM
jdrames
Lancer Troubleshooting
Jun 3, 2016 02:38 PM
Hanzo OZ
Sep 29, 2012 09:35 PM
WADADLIG_OZ
Feb 9, 2005 02:35 PM
lancer r us
May 17, 2003 11:13 AM
