Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Can anyone post instructions on how to paint interior?
Old Dec 15, 2004 | 11:52 AM
wingnut17's Avatar
Can anyone post instructions on how to post interior? Thanks
Old Dec 15, 2004 | 12:14 PM
blacklancerr's Avatar
sure...here's a link
https://www.evolutionm.net/forums/search.php
Old Dec 15, 2004 | 12:22 PM
Evokid04's Avatar
There are a lot of threads about this subject. I'll tell you what I know because I helped out my friend on his OZ, however, you should also look a little harder because some people have better details.
1. First I would use rustoleum spray paint. It really good quailty spray and it won't chip as easily as Krylon and Duplicolor. It may cost a few more bucks, but it's worth it. You'll also need clear coat (same brand) and maybe some sandpaper (just in case you mess up)
2. Once you removed your panels you should wipe them from dust and put them in a even level area.
3. If your not handy with the spray paint I would get someone who is. (That's when my friend asked me for help)
4. Don't spray directly on the panel. You want to have a nice right to left action or vise versa. Let the middle part of the action be on the panel because thats when its less thick and the most even.
5. After a few hours clear coat it. Do it every hour or so for 2-4 days.
6. I would suggest waiting 2-3 days before installing the parts back. The clear coat should have done its job to make the paint smooth,shiny, and help prevent it from chipping. It took my friend and I about 1.5 weeks because we painted the big panels first then worked on the little ones. Good luck.
Old Dec 15, 2004 | 07:20 PM
OZLancerlunatic's Avatar
ummmm Crayola water colors and a paintbrush....
lol, I used Duplicolor Engine Enamel. First I prepped all the pieces with a plastic priming liquid to rough them up a bit, then 2 coats of primer and 3 coats of paint and 2-4 coats of clear. came out nice =)
Old Dec 15, 2004 | 07:25 PM
timdog4life's Avatar
remove, clean, sand (if desired) , prime, paint, let dry, paint again/let dry (if desired), clear coat....lots and lots of clear coat. Theres actually one I posted on here for using the mirage color change paint. I think you just need to search for "painting dash" but its probably buried under the 100 other ones of the same title. Good Lucks and post pics.
Old Dec 15, 2004 | 07:33 PM
wingnut17's Avatar
That's what I was planning on doing. I just wanted to double check with someone else that I wasn't forgetting anything.
Old Dec 16, 2004 | 09:38 AM
Evokid04's Avatar
Well yea thats like the basic stuff I put but it should get you on the right track. Hopefully more people will give there tips because it would suck to do so much work and have it looking like a half *** job with cracks and chipping. By the way, keep me updated and once your done, post up some pics if you can.
Old Jan 15, 2005 | 02:34 PM
clovis112's Avatar
yeah pics of the final project..
Old Feb 26, 2005 | 10:58 PM
Hilton_K's Avatar
Can we get a how to remove dash to go with this?? Painting door trims etc is easy as they come out easy, what about the dash though has anyone tried to pull it apart piece by piece??
GearJamminMR
Sep 7, 2016 03:02 PM
42revoincali
Oct 31, 2010 02:12 PM
57LTH
Aug 7, 2009 04:23 PM
JRB_EVO
Aug 28, 2006 09:44 AM
bishiboy
23
May 14, 2004 12:14 PM
