Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
where to begin upgrading lancer es
Old Jan 10, 2006 | 11:31 PM
mikethecoder's Avatar
hey everyone... i had somewhat recently purchases a 2003 lancer es, automatic, 60k miles. i want the car to last quite some time so i am interested in upgrading with as much being performance parts as possible that will last and maybe even give a bit more speed to the car.
i was just curious what everyone thinks would be best to begin with. even just small things like a new cold air intake etc. ill eventually want a magnaflow exhaust system and new suspension system too.
but yeah...what do you feel is the best to begin working on first that will help/make the biggest difference??
any help is much appreciated.
Old Jan 10, 2006 | 11:36 PM
fromWRXtoEVO's Avatar
Go to lancer shop.
Good luck but you will have really hard times making that car any faster, it will take you a whole lot of money and mods. Go to AZlancers, there are a couple of guys that have turbos on their lancers, that is a good starting point.
I wish you the best of lucks because you will need nearly half of the money of what you paid for the car to make it fast. I am not trying to be an a$$ here, I am just trying to demostrate that the mods on a Lancer engine make absolutely minimal power and the expenses are just so disproportional.
Old Jan 10, 2006 | 11:45 PM
grubiaco's Avatar
go to roadrace corner.
They suggest a certain modification route.
Old Jan 10, 2006 | 11:48 PM
grubiaco's Avatar
You should also try searching because there are a lot of helpful threads relating to your topic. In any case, here is a direct link to the specific article because it can be hard to find.
https://www.evolutionm.net/features/...e/rrmcorner/16
EDIT: see my sig if you are looking for a cold air intake.
Old Jan 11, 2006 | 08:31 AM
yeah i know the problems with trying to make a lancer faster.... usually it amounts to just buying the evo to begin with. im not really worried about getting the fastest car i can from my lancer. i just want to replace most parts with performance ones so the car will last a long time and stay new. now if the parts i happen to change will also give me a small HP boost then that would be cool too.
Old Jan 11, 2006 | 10:22 AM
mitch44759's Avatar
Start saving you money for a turbo.. I started with cold air noticed nothing but a little more noise, then i got the magna flow CAT back and noticed a little pick up diffrance. But all in all when i got my turbo i would say it has been by far the best thing i could do.
Old Jan 11, 2006 | 02:55 PM
Zippo41189's Avatar
turbo... its the only way, and the cheapest unless your a dumb *** and try nos...which i hope your not. i have an auto es 2003 too and had the same questions as you. so i made some $$ and am starting too, but if i can/will do one thing different its start on a turbo. so do that first, same for a turbo and make so HP and clean out that engine with some boost!
Old Jan 11, 2006 | 05:24 PM
mitsuozboi's Avatar
I say start with intake, since you have an auto i think you have to go ram air unless you move battery to trunk (correct me if im wrong). then header + full stainless steel exhaust system. tein coilovers. To help with frame flex if you like to drive fast get some sway/perch bars. mabey upgrade to slotted brakes and better pads. steel braided brake lines. all I can think of right now. happy modding your new lancer.
Old Jun 4, 2013 | 10:44 AM
americanevo's Avatar
brakes
unless your going on the track a lot! I would steer clear from drilled and slotted either get full ones or slotted only. drilled and slotted tend to crack easier on daily driving. well I have been told so and seen it in my a few of my friends cars.
Old Jun 28, 2014 | 09:50 AM
smcm24's Avatar
If u get headers the car will be loud af and personally I think it sounds dumb and ricer.
Old Jan 4, 2015 | 07:27 PM
RukusLAX's Avatar
Have to go with the headers to get all the power you can with the exhaust system.
2K15LancerEs
Lancer Aftermarket Forced Induction Tech
Jun 23, 2017 08:47 AM
2K15LancerEs
Lancer Engine Tech
Nov 9, 2015 06:08 AM
bxrice1708
Lancer Engine Tech
Dec 4, 2012 04:57 PM
arock90
Lancer Engine Tech
Nov 1, 2012 07:01 AM
TaKectrLANCER
18
Oct 12, 2012 03:50 AM
