Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Quick Question
Old Nov 1, 2007 | 06:48 PM
08 lancer De's Avatar
Quick Question
Do you guys think the evo 8 motor will fit in the 08 lancer at all if it does that i'll be great but just curious
Old Nov 1, 2007 | 06:52 PM
angryGTS's Avatar
With the right funds to do it, anything is possible....If it does work it most likely wont be cheap, u would most likely need custom mounts and other custom parts
Old Nov 1, 2007 | 10:39 PM
08LancerEVO's Avatar
i think it will be fairly easy, their roughly similiar in shape, custom motor mounts yes, and an ecu maby, idk. if i ever drop in motors its allways a chevy big block or somethin
Old Nov 2, 2007 | 08:59 AM
Blacksheepdj's Avatar
Will it physically fit in the engine bay? Yes.
Will it go right in, bolt right up and plug right in? HELL NO.
Old Nov 2, 2007 | 02:44 PM
all right guys thanks
Old Nov 2, 2007 | 02:46 PM
how about the evo 10 motor motor will that fit and bolt right up
Old Nov 2, 2007 | 03:21 PM
Hawkeye's Avatar
The Evo X engine is the 4B11T. Could you swap your 4B11 for a 4B11T? Probably, and it might be easier than swapping with previous Evolution engines. It'll be more expensive though; new systems and all.
Will it plug and play? HIGHLY doubtful.
Old Nov 2, 2007 | 04:30 PM
all right thanks
Old Nov 2, 2007 | 08:02 PM
Eagles GTS's Avatar
After the you spend the money on an evo x motor and the entire swap you could buy an EVO X. This isnt a very practical idea and the OP is probably just creating buzz
Old Nov 2, 2007 | 09:01 PM
damn
Old Nov 3, 2007 | 07:11 AM
It should bolt right up since it's the same motor.
But you know the ECU won't match. The normal 4B11 and the 4B11T are going to be tuned dramatically different.
As said, if you want a turboed Lancer, you need to trade the DE in for a X.
Old Nov 3, 2007 | 05:15 PM
o ok
08lancer08
Aug 5, 2011 03:18 PM
Daskid
Oct 15, 2009 08:17 PM
slaker138
For Sale - Wheels / Tires / Suspension / Brakes
Jun 17, 2009 02:16 PM
Defcon5Es
Sep 5, 2008 12:51 AM
08 lancer De
58
Dec 29, 2007 12:43 PM
