Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Interior neons on my GTS
Old Mar 4, 2008 | 10:02 AM
DirectorSe7en's Avatar
You're really going for that "rice" look aren't you?
Skip the neons, save up for some real, non-AutoZone parts.
Old Mar 6, 2008 | 01:37 AM
CamShaft's Avatar
yeah still trying to wire up lights, no matter what brand are going to take some electrical skill/knowledge. This lancer is as advanced as the rest of them
Old Mar 6, 2008 | 06:42 AM
Davedangerous's Avatar
use the door trigger as the ground for a relay, take 12v from acc wire and go from there. I'm not sure what the lancers wiring diagram is, but if theres a keyless entry module there might be a dome light supervision wire. You could use that to trigger the relay with a constant gound.
Old Mar 6, 2008 | 07:02 AM
-terminal 85 is your power source (12v + fused from battery)
-terminal 86 is your ground - (dome light supervison - wire, or door trigger)
-terminal 30 is looped from teminal 85
-terminal 87 is the 12v+ going to the lights
Your next step woul be to find a good spot to ground the lights
I think i wrote that up correctly.
Dave
Old Mar 6, 2008 | 09:25 AM
CamShaft's Avatar
Yeah, thats how u wire up a relay,basically. You do need a ground for the relay though, whether that be the door switch or or whatnot.
Your problem is that all the doors send a singal to the ECU for the dome light (just had it programmed to dim after 15 sec. not 30.) The signal might run only off 5 V, not enough to light up neons.
And tapping into one without knowing what you are doing could throw some fault codes, and at worst mess up your ecu. So just know what you are doing and do it right.
Old Mar 6, 2008 | 10:54 AM
you need less than 5v to power the relay, not the lights. I figured that when the dome light turns on, the relay is now closed turning on the neons. and when the dome light goes the relay becomes open shutting the neons off.
Old Mar 7, 2008 | 12:49 AM
CamShaft's Avatar
True true, I may have read it wrong, but thats what we do for aftermarket lights on volvo trucks so it doesn't pull more amps throwing a code for the LCM.
That will work, so just look for the output wire on the door lights at the etacs-ecu (i believe its right behind or part of the fuse panel inside our cars) Just dont forget to fuse the power side for your light off the relay.
GTS08
Jan 8, 2014 03:47 AM
LancerNewbie
Apr 23, 2007 05:13 AM
night_hawk
04-06 Lancer Ralliart How To Requests / Questions / Tips
11
Nov 24, 2006 03:13 AM
sinaloa86
11
Feb 23, 2006 11:40 PM
pickleknock
Northwest Region
24
Oct 22, 2004 06:45 AM
