Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Upgrading
Old Apr 23, 2009 | 05:41 AM
MGSGreyF0x's Avatar
Upgrading
I have an 03 Lancer ES, and was wondering what I should get for it. I was thinking the big thing would be to change out the engine for an Evo, but what year should I do it with? Also, how hard would it be to change the tranny from auto to manual? I'd need to install a shifter, as well as a clutch pedal, but what else would I need?
Old Apr 23, 2009 | 07:14 AM
Noe18's Avatar
remember that evo is all AWD, es is FWD
Old Apr 23, 2009 | 08:00 AM
MGSGreyF0x's Avatar
I did not know that. Any suggestions as to what I need to do for it?
Old Apr 23, 2009 | 09:48 AM
Noe18's Avatar
to be honest it req allot of work and money are you up for it??
Required AWD Parts
Transmission
Transfer case
Front axles
Drive shaft
Exhaust
Fuel tank and shield
Rear subframe
Rear axles
Rear differential
Swaybar
Rear knuckles
E-brake cables
AWD Flywheel
Old Apr 23, 2009 | 10:00 AM
Noe18's Avatar
tranny is not that hard but you have to fab and or weld cause is going to be bigger i think not really to sure, just make sure you google and ask some evo member here for more info, by the time you finish you will think about getting a evo
Old Apr 23, 2009 | 08:32 PM
jdparadee's Avatar
save yourself the hassle and just get a turbo kit for the one you have, and if you really want a manual i would say go buy one, is a pain to change an auto for a manual, but anything can be done with enough $$$$$ and time.
Old Apr 23, 2009 | 08:40 PM
Import Junky's Avatar
i can't believe you're even getting serious responses. This is just a rediculous idea. If all you can afford is an old lancer es auto then don't even bother spending the cash to modify the crap out of it. Just the idea of this swap alone would set you back thousands of dollars and tons of time and heartache. Just go buy a 2003 Evo for about 15k and you'll be miles ahead of what you're trying to accomplish the hard way.
Old Apr 23, 2009 | 08:55 PM
ambystom01's Avatar
If you didn't even know the Evo is AWD, you shouldn't mod at all. I suggest you start by reading the FAQ linked in my sig.
Old Apr 27, 2009 | 12:25 PM
Ozrally06's Avatar
Here are some lancer with 4g63 fwd and you have to getsome better axle since the stock ones will snap from all the new hp/tq ithink here are some write ups for them I cant remember witch ones tho
Old Apr 27, 2009 | 12:30 PM
bcollinstex's Avatar
None of the things you listed is going to be easy even for a seasoned mechanic.
Best bet is to get a turbo kit. You'll be able to double horsepower without puting in new internals.
