Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Request How to : Install Amp & Sub
Old Feb 27, 2010 | 12:24 AM
holycrap300's Avatar
hey, do some1 can make an how to install Amp & Sub in lancer 05? pls. The post in how to about this is empty and the link isnt working anymore.
I'd appreciate it thnx
Old Mar 4, 2010 | 01:13 AM
03lances's Avatar
Its actually really simple, you will have to run a BIG power wire (I have 4gauge wire but it all depends on how much power your amp outputs)all the way from the battery to wherever you have your amp (I assume the trunk of course) Then you should have a bolt under your carpet in your trunk in the rear left corner that you can use as a ground. Your remote wire can be tapped into your cigarette lighter wire right under the center console should be pretty easy to get to. Then its just a matter of connecting some rca cables to the back of your deck (or if you have a stock deck with no preamps you can get a line out converter from radio shack and splice into your rear speaker wires) and connect your rca's to that. Connect your subs to your amp and BOOM BOOM baby lol
Old Mar 4, 2010 | 10:16 AM
nice thnx but i cant find the firewall to get the power wire get into it to the trunk
Old Mar 4, 2010 | 11:00 AM
03lances's Avatar
Well if your battery is behind the drivers headlight like mine is then you can run it down the fender like me then and bring it in that way I have mine then going behind the dirvers side kick panel and ran under the carpet.
Old Mar 4, 2010 | 11:08 AM
ok thnx for help!
Old Mar 4, 2010 | 12:05 PM
03lances's Avatar
Sure thing bro
Old Mar 4, 2010 | 04:04 PM
i have done it, but something is wrong since the sub isnt working, gonna double check tomorrow
Old Mar 4, 2010 | 04:20 PM
03lances's Avatar
Check to confirm your grounds.
Old Mar 5, 2010 | 09:05 AM
i found it, its missing the remote wire
Old Mar 5, 2010 | 01:41 PM
everything is working fine with disturbed and linkin park !!!
Old Mar 5, 2010 | 01:47 PM
03lances's Avatar
Cool bro glad you got it working
D420mac
Mar 6, 2011 12:51 PM
b s t a r r
27
Apr 4, 2008 09:03 PM
RyanEvo2006
Dec 28, 2006 02:43 PM
JonPug
Dec 14, 2002 11:29 PM
Scottp
Jul 9, 2002 03:02 AM
