Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How to unlock DVD in Motion on MMCS
Old Feb 4, 2010 | 12:55 PM
  #46
RTW EVO's Avatar
Originally Posted by nsk_tigz38
I really dont know what im doing wrong, but i burnt it twice and both cds were not readable
can anyone give me any advice on what might i try differently?
So i need to update my version and then unlock the DVD in motion?
Silly question... but did you unzip the files before you burnt it?
Old Feb 4, 2010 | 01:01 PM
  #47
imdrew12's Avatar
Good question. You need to burn the .iso not the .zip file.
Old Feb 11, 2010 | 09:58 PM
  #48
Mivo's Avatar
ok so what one do i burn loading or all data or both?
Old Feb 12, 2010 | 07:37 PM
  #49
Mivo's Avatar
ok so ran into a problem today. i unzipped the loading and all data to a disk. i inserted the disc as i started to drive to work, not thinking that it would interrupt the process lol it was very early. so then after work i put the disc back in and it says its updating program version or something then it stops and says "dvd drive does not work turn off engine key to retry." at this time the car is on acc and not moving, and now i cant get "insert program disc" off my screen. any suggestions? please help i cant stand this and dont want to take it to mitsu...
Old Feb 12, 2010 | 08:19 PM
  #50
Mivo's Avatar
i just f'ed myself in the a huh?
Old Feb 13, 2010 | 12:03 AM
  #51
Defcon5Es's Avatar
You're MMCS is f-up. Maybe someone else can help you with this problem. This is why i ask first before i do anything with it. Lesson learned my friend.
Old Feb 13, 2010 | 11:02 AM
  #52
Mivo's Avatar
ya pretty much guess i shouldnt be so impulsive.
Old Feb 15, 2010 | 09:41 AM
  #53
brian360's Avatar
Very unusual that you got a DVD Drive error and now it can't read from the HDD. My suspicion is there is another fault in the MMCS -- maybe the hard drive just came loose?
Is the unit still under warranty? If so, take it to them to fix. Otherwise, if you're reasonably technically inclined, you can try removing the hard drive and patching the files manually.
Old Feb 19, 2010 | 11:10 AM
  #54
chicko89's Avatar
i did everything that you wrote over there.. but once it reboots it says program detected and i hit no and then when i take the cd out while it reboots its back to normal... when i drive the message still appears "it can not be viewed while driving whatever that message is" so am i doing something wrong?
Old Feb 22, 2010 | 09:00 PM
  #55
nsk_tigz38's Avatar
Finally got this thing to work. Just updated my system then downloaded the above link, poped in, update and everything is crisp. thanks alot
Old Feb 27, 2010 | 05:06 PM
  #56
Jake26's Avatar
OTAKU any idea if the 00.40.11 will work on 00.40.32 ?? i have 00.40.32 version
Old Mar 8, 2010 | 09:23 AM
  #57
LocoStrange's Avatar
Nevermind... fixed it
Old Apr 2, 2010 | 02:20 PM
  #58
Defcon5Es's Avatar
Which one of the files i should use?
Old Apr 6, 2010 | 10:38 PM
  #59
laksman91's Avatar
success on 3.99! took me just 5 minutes for it all
Old Apr 21, 2010 | 08:19 PM
  #60
jonnyweb's Avatar
Just ran this on my 08 GTS and it worked like a champ. Backed car out of drive and pulled back in without issue. Thanks for this, will come in handy when i'm stuck in traffic to and from work!
If only someone had something this simple to update our NAV
