How to unlock DVD in Motion on MMCS
First of all, thanks to those who created this guide.
I found the files to update on my model of MMCS, but once completed the process and content while wandering around the city feeling (and looking a little of course) a music DVD, I arose a doubt and I connected a cable to the AUX connecting my iPhone (I know that when you can not view the album or the contents into individual tracks, you can not change album or track, practically uses only the car's audio system by raising or lowering the volume) appeared in the famous writing that you can not use the move.
So now at this point: Unlocked DVD, AUX blocked (this is what most interested me, since I plan to connect the Blitz R-VIT DS).
Some help to unlock the socket AUX?
Have tried this a few times, and its not working for me. I copy the .iso file correctly to a cd-r using
iso recorder, and I even check to see if the files have copied correctly to the cd-r (which they have, it has 2 files on the cd-r). But when it tries to read it it tells me to check the disc...
Im running 30.94 in my 2008 Evo X MR so I know its not because there isn't a hack for my MMCS.
Kinda of lost and disappointed @ this point. Any insight? Can someone link me to the file that should work for my system (in case for some stupid reason I have the wrong .iso/rar)?
From other forums I have read, people are using the 30.99 version to update their 30.97 MMCS. Off hand I don't have the link to the other site, but it's another lancer/mitsu site.
I can't get this to work for some reason. I've tried this on 5 discs now. Somewhere I read that some CD-R's don't read correctly in the MMCS. I tried from Memorex CD-R's and when I burn the ISO on CD it starts to read the disk, then just doesn't do anything. When I burn the ISO image of the 2 files on disk it starts to say "Reading Disk" then a minute later it says "Check Disk".
On the TDK CD-R's I tried it just wouldn't do anything, so I'm guessing the reader doesn't like those. But at least with the Memorex it gave me the message to check the disk.
Am I missing something? I've tried using PowerISO and Nero to burn the ISO image to disk, but neither attempts have worked. I also tried to use ISOburn, but I don't think Windows 7 supports the program as it keeps giving me an error that it can't launch a command to burn.
Any ideas? What program have people used to burn the ISO that works? And does it need to be a bootable ISO or just burn the files in the ISO to CD-R?
Found this reply in another thread and thought I would post it in here too just in case anyone else with an 09 has this issue:
Works great with my 2009 Lancer GTS.
Loader- BLD-NR-261 UM 1.09
Application- 00.30.94
Used image http://www.deltainfo.ro/manuals/mits...MMCS-261UM.iso
Burned image with Image Burn
Popped it in, asked to update..said yes...updated successfully then rebooted, asked to update again..said no, tested and works great! Thanks every1.[/
just wondering. you know how with most aftermarket headunits most installers have to ground the HU to the ebrake so that the customer can't watch while driving. well couldn't we just do what most people do and ground that wire else where. if we have a set-up that is similar to most after market HU that is.
you have to burn it with disk image burner
Go to clubcj.net as you find all the answers you require there including how to dissable speed motion sensor to watch dvd.
