How do i install LEDGLOW on 2002 Lancer
I am almost done installing the LEDGLOW for my 2002 Lancer , but I have to connect a red wire to one of my fusses under the drivers side. The fuse has to have 12 Volts of power . I don't have a multimeter or anything how am I supposed to know which one to connect it to . And I don't want to blow a fuse.
I can't answer your question, but I'll play nice. All voltage in a car is 12-14 volts, it's all you'll find because that's the range in which your battery functions. And if you're dealing with electricity you should be using some form of voltage tester. You don't want to be driving down the road & your car catches fire because you were cheap, or just decided to take someone's opinion over the Internet. Good luck.
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
SatsuMX
Feb 22, 2016 08:38 AM
