Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
The big Mirage-Lancer thread
Old Jun 21, 2008 | 09:18 AM
  #61
Mirage4g93's Avatar
I don't know that there is a dedicated thread to it. It is almost the same exact part. The 4g93 manifold just flows better.
It otherwise bolts up the same. Has the same sensor locations and everything else that the 4g94 manifold has.
Old Jul 20, 2008 | 07:14 PM
  #62
JuanBond's Avatar
Originally Posted by *Zero*
header does fit on the car with mods. to the header and downpipe(if there)....
i put it on with no CEL either and runs smoothly...
HP is ok but TQ is noticable....
Which yr mirage is that off of? i want to use the turbo manifold from the mirage!
Old Jul 23, 2008 | 09:11 PM
  #63
Mirage4g93's Avatar
any 5g mirage turbo manifold will work on a lancer. 97+ Mirage
Old Aug 27, 2008 | 07:34 PM
  #64
Jehuty's Avatar
Quick question.....if I wanted to do a manual tranny swap on my 02 lancer would a 5 speed manual tranny work in my lancer?
Old Sep 8, 2008 | 11:20 PM
  #65
KillahB's Avatar
I told you yes, jackball. The only differences are minor, like gear ratios and such. I'll double check on the mirage board but I'm almost certain.
EDIT: I'm sure you know you need much more than just the gearbox, right?
Old Sep 9, 2008 | 04:58 AM
  #66
Jehuty's Avatar
I posted this up BEFORE I even asked you douche ball, lol. I was looking at u pull and pay to see if I can get it from there. Good idea, no?
Old Sep 9, 2008 | 08:57 AM
  #67
KillahB's Avatar
Yessir.
Of course you need linkages, pedals and all that crapola too. Still waiting on replies on the other side.
Old Sep 9, 2008 | 10:58 AM
  #68
Jehuty's Avatar
Yeah but it seems to be the cheaper route for a tranny swap
Old Sep 29, 2008 | 03:36 PM
  #69
hcj's Avatar
hcj
i have read the entire thread and i understand the the mirage clutch(disc and pressure plate) will fit on a 2002 OZ lancer
looking around the option i found this Exedy Kit for the mirage
Item number: 180290528345
could someone confirm if this will really fit
thanks
Old Dec 22, 2008 | 06:09 PM
  #70
bad ass oz's Avatar
manual tranny swap on my 03 lancer would a 5 speed manual tranny work out of the mirage and what year would i need to go with
Old Dec 30, 2008 | 06:42 PM
  #71
Tnastyevo8's Avatar
Veteran: Navy
Old Jan 13, 2009 | 05:22 PM
  #72
cyrax5709's Avatar
OK so going to junkyards and looking at other 4g series motors ive noticed one main difference with the setup between the 94 and 9X/6X. The TB always seems just a little different. I was looking for a throttle position sensor. (I think mine is messing up but i wanted to swap it out to see if it made a difference before I bought a new one from the dealer). All the ones I can find look adjustable. The screw holes are long like you can turn it. on the 94 they arent. Any ideas? I did however find a Mass Airflow sensor that had the same part number on it. I think it came out of a mirage with a 4g15. Dont hate if Im wrong. Any advice would help though
Old Jan 13, 2009 | 10:02 PM
  #73
Evo666's Avatar
4G15 doesn't have any MAF
93-02 mirage all have adjustable TPS
Old Jan 14, 2009 | 08:01 PM
  #74
cyrax5709's Avatar
Well...so is there any other mitsus that have the same TPS as the 4g94?
Old Jan 19, 2009 | 01:40 PM
  #75
Evo666's Avatar
Can you show me a picture of your TPS?
