Need Wiring help for an Alarm
Old Jan 18, 2007 | 08:14 AM
MyRoN's Avatar
Hey guys, i got a new alarm and tackled it last night. But the alarm has a wire for 500 ma and thats a starter disable. I have no idea where to find thar wire, Also if any one has the color and locations of the dome lights and the Head lights. I want those lights to light up when my alarm is activated or de activated.
any help will be really nice becasue i have my car torn apart with wires everywhere
thanks
Old Jan 18, 2007 | 09:32 AM
Myszkewicz's Avatar
Starter disable can be accomplished by completing the clutch safety switch circuit. It's a normally closed circuit that opens when you step on the clutch pedal and trip a switch. You would want to close the circuit regardless of the switch when the alarm is activated, and open it again when it's deactivated.
Otherwise, the starter relay that is controlled by the safety switch is under the hood, under the long, thin black cover on the driver's side. Apply power to pin #3, and ground pin #1 to disable the starter.
Old Jan 18, 2007 | 10:04 AM
MyRoN's Avatar
Thanks alot....any pics or diagrams to go with that?
appreciate the help.
Old Jan 18, 2007 | 10:13 AM
Myszkewicz's Avatar
Here you go:
Diagram
Whoa, huge pic. Linked instead.
Old Jan 18, 2007 | 10:34 AM
MyRoN's Avatar
Very Nice..Now i just have to find out how to read it....I see the colors and following the wires.
thanks alot
Old Jan 18, 2007 | 11:04 AM
Myszkewicz's Avatar
thanks alot
+12v at the top of the diagram, follow the wires through switches, relays, etc., to ground at the bottom.
Ground symbol looks like this:
__O__
___
_
Old Jan 19, 2007 | 11:19 AM
MyRoN's Avatar
OKay, i did all that, but something on my alarm is not working.
I see that on the back of my fuse box in the kick pannel, there are 2 wires that operate the door locsk, the colors i belive are violet and green (light), and in the front of the fuse box there is a white wire that unlock the door when u use a test light to it.
and then there is a yello wire that locks it and another one that unlocks it. only when i touch a test light to it.
is there any where i can get the lay out of the kick pannell and the wires, that will tell me what exactly those wires are for? or am i asking for the impossible?
thanks...
myron
Old Jan 19, 2007 | 11:31 AM
Myszkewicz's Avatar
Door lock wiring diagram
prawln
Jul 19, 2011 03:58 AM
Griffin5
Dec 17, 2009 09:40 PM
boostedteg99
Jul 10, 2009 12:58 AM
evo_shibby
10
Mar 7, 2007 07:17 PM
evoballa21
Sep 7, 2004 12:05 PM
