Deadening kit
Old Apr 22, 2007 | 07:51 PM
Realistic's Avatar
Deadening kit
hey guys,
just wondering who has installed the dynamat deadening kit and how well it works with your subs? how much material do you need? 5 sheets? which kit did you end up buying? worth the money? i'm going to ebay it I think. 50 US is alot better then 200 canadian.
well, it's ALMOST the same :P ahahaa
Thanks everyone who posts!
Old Apr 23, 2007 | 06:09 AM
blkbute's Avatar
Go to the hardware store and get some peel and stick roofing membrane. Compare it to dynamat and see that you can get a roll to do you whole car 2 times costs $80-$100 for the same product. Its just a little thinner so put on 2 layers and then its thicker then dynamat. I have worked with both dynamat and roofing membrane I found the membrane a lot easer to work with and works just as well.
Old Apr 23, 2007 | 06:42 AM
otter's Avatar
EvoM Administrator
I've got dynamat in my truck. Bought their trunk kit off of eBay for around $40 I think. Worked well, kept everything nice and tight back there. Downside - I don't crank my system up as much as I used to and I'd like to get rid of the dynamat to save some weight. Heh, that's going to be a pain. Hopefully the dry ice idea will work, but we'll see.
Old Apr 23, 2007 | 08:51 AM
bruce988jl's Avatar
Otter the dry ice will work, its slow and painful but just don't burn yourself with the ice. I've seen it done. Also i'd heard a lot of good things about using the roofing membrane stuff, i'm cheap. But i don't mind rattles..
Old Apr 23, 2007 | 07:54 PM
Myszkewicz's Avatar
I was thinking about getting some B-Quiet for my car. Dynamat is too expensive.
Old May 7, 2007 | 06:42 AM
atombomb33's Avatar
EvoM Community Team
There is also this stuff called Fat Mat. I've seen comparison tests and it's basically identical in performance to Dynamat Extreme. Except, it weights only half of Dynamat Extreme and is way cheaper. $100 for 100 sq.ft. and that 100sqft only weighs 23lbs. Same amount for Dynamat would weigh like 45-50lbs. Go to www.fatmat.com. I did and love it!
Old May 10, 2007 | 03:03 PM
URNVS's Avatar
It works good unless you are in an extremeley hot climate where the adhesive can wear out fast...speaking of which there is a company here in Phoenix that makes 'generic' dynamat for about 1/2 the cost. They also have the spray in mix which I think works WAY better.
Old May 10, 2007 | 07:27 PM
Realistic's Avatar
The spray stuff? aerosol can spray? how does it work ?
Old May 10, 2007 | 08:42 PM
URNVS's Avatar
You need a spray gun and air compressor, pretty much like painting but its real thick stuff so make sure you keep the pressure low or you will blow out the canister...I think Dynamat actually makes a rattle can version but its much more expensive.
InitialE
Jun 30, 2016 11:52 AM
Stop&TurnFreak
Jul 14, 2010 07:27 AM
Inprogress
62
Jun 24, 2009 05:43 AM
yitzac1990
Feb 9, 2009 03:31 PM
EvoIXMR
Oct 2, 2007 04:05 PM
