Is my lancer a gts ?
Old Jan 15, 2012 | 09:58 PM
wumbster's Avatar
I bought a used 2010 lancer with 12,000 miles three months ago and the salesman said it was a gts model. It has a tipped exhaust, stock spoiler and paddle shifters. I went to get an oil change and when I checked under the hood the sticker said it was a 2.0 litter engine. Gts engines are 2.4. Is my car a gts? Is the sticker mistaken?
Is this common? Thanks
Old Jan 15, 2012 | 10:15 PM
02-Lancer-Es's Avatar
Is it Turbo?
Old Jan 15, 2012 | 10:16 PM
My 08 Gts says its Awd under the hood lol
Old Jan 16, 2012 | 09:10 AM
wumbster's Avatar
Originally Posted by 02-Lancer-Es
Is it Turbo?
it is not a turbo
Old Jan 16, 2012 | 01:50 PM
CrAnSwIcK's Avatar
what sticker? and you know you're in the 04-06 ralliart section right?
should be a plate (not a sticker) in the engine bay, or somewhere on the car that tells you the engine code...4B12 is 2.4L
Old Jan 17, 2012 | 09:50 AM
SYSTEMA's Avatar
if you're going to make multiple threads for the same question on different boards then at least have the courtesy to check each of them. im trying to help you out here lol. heres my reply from your other thread.
Originally Posted by SYSTEMA
thats weird. you do have a gts because of the paddles, but if you think you have a 2.0 engine than you may have bought a 2008 gts
check the engine code that is engraved where the oil filter is mounted.
open you hood and look down in the space in between the radiator and the plastic intake manifold.
you should see a piece of metal that has the oil filter below it (right under the plastic intake manifold).
on that piece of metal there should be one of three codes
4b10 is the 1.8L
4b11 is the 2.0L
4b12 is the 2.4L
post a pic of your engine bay and i might be able to tell based on the engine cover.
the code will be on the right side. see the pic for reference
Old Jan 17, 2012 | 11:22 AM
nekkidlad's Avatar
or you can type the vin into a decoder....heres a link to one..
http://www.motoverse.com/tools/vinDecoder.asp
(type your vin in the bar and then type the "secret code" thing in...and hit decode)
Old Jan 18, 2012 | 06:29 PM
wumbster's Avatar
Thanks for the pic, really appreciate it. I found it and it said it was a 2.4 liter.
Thanks to all who helped!
EvanReynolds
Lancer Engine Tech
Mar 15, 2014 06:28 AM
lancerguiii
Lancer Engine Management / Tuning Forums
15
Dec 22, 2013 07:56 AM
wumbster
15
Nov 15, 2013 08:54 PM
GTS08
18
Aug 21, 2007 01:09 AM
