Can someone confirm asap???
Old Mar 14, 2012 | 12:57 PM
roblaza's Avatar
I'm installing an alarm in my 05 RA. I have no issues doing the wiring (I rather enjoy it)...Please do NOT criticize, I just need Wire colours. I found the following, but would like to know if the colours are correct...It seems to me that there's some missing though......
2005 MITSUBISHI LANCER 4DR SEDAN
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger WHITE (-) FUSEBOX , WHITE PLUG AT BOTTOM
Domelight Super USE DOOR TRIGGER
Trunk Trigger GREEN/ORANGE (-) TRUNK LIGHT
Alarm Disarm GRAY
Parking Lights GREEN/YELLOW (L) GREEN/WHITE (R) (+) FUSEBOX , WHITE PLUG AT BOTTOM
Convenience
Headlights-Lo RED/YELLOW (L) PINK (R) (+) RELAY CENTER UNDER HOOD
All Hazrd Lights WHITE (-) HAZARD SWITCH
Wipers-Lo BLUE/RED (+) WIPER MOTOR
Wipers-Hi ORANGE (+) WIPER MOTOR
Parking Brake BLUE/RED (-) PARKING BRAKE SWITCH
Remote Start
Accessory 1 BLUE/BLACK (+) IGNITION SWITCH HARNESS
Accessory 2 BLUE/WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type SOME MODELS HAVE RF TYPE IMMOBILIZER SYSTEMS
Key Sense BLUE
RESTS AT GROUND OPEN WHEN KEY IS IN, USE RELAY TO OPEN.
Tachometer BLACK/YELLOW (-) IGNITION COIL
Speed Sense BLACK/RED (AC) DIAGNOSTIC CONNECTOR UNDER DRIVER DASH
Brake Lights GREEN (+) BRAKE SWITCH
Reverse Lights BROWN (+) DRIVER KICK PANEL, HARNESS TO REAR
Horn BLUE/RED OR RED (-) HORN SWITCH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock LT.GREEN (-) DRIVER KICK DOOR HARNESS
PowerLock VIOLET (-) DRIVER KICK DOOR HARNESS
Driver Mtr Unlock WHITE (REV) DRIVER KICK DOOR HARNESS
Driver Mtr Lock BLUE/RED (AC) DRIVER KICK DOOR HARNESS
LF Window Up RED/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
LF Window Dn GREEN/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
RF Window Up BLUE/WHITE (REV) DRIVER KICK DOOR HARNESS
RF Window Dn BLACK/WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Up WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Dn BLUE (REV) DRIVER KICK DOOR HARNESS
RR Window Up BLUE/BLACK (REV) DRIVER KICK DOOR HARNESS
RR Window Dn GREEN/YELLOW (REV) DRIVER KICK DOOR HARNESS
The following is the wiring for the brain, I just need to know where the wires are and what colour for each one....
Old Mar 14, 2012 | 03:59 PM
CrAnSwIcK's Avatar
do you just splice onto the wires?
Old Mar 14, 2012 | 04:38 PM
stockley1234's Avatar
You've Got Mail!
http://youtu.be/gFBLiHpkcOk
Old Mar 14, 2012 | 05:20 PM
roblaza's Avatar
Holy crap..... MOST. DETAILED. INFORMATION. EVAR. Thanks Matt, much appreciated!
Old Mar 14, 2012 | 06:08 PM
No problem Rob.
I have been digging for the most accurate sources on this topic for 2 years now and after finding bug-filed, misguided information which lacks proof, these have been the best. I have a Viper 5701 which I plan to install one of these days, but wanted to have rich information so I am not misguided into blowing something up (something that is not a stretch for me)
To everyone else,
Unfortunately I cannot, well I can, but I will not post the information that I gave to Rob on these forums; but if you are planning on installing a car starter and/or alarm, then just drop me a PM and we can go from there.
Old Mar 14, 2012 | 06:56 PM
roblaza's Avatar
If its okay with Matt, I can also distribute this wiring info to those who need it... But only if it's okay with Matt. Those who need it can also pm me. And so everyone is clear, there is a very good reason as to why it wasn't just blatently posted on the boards.
Old Mar 14, 2012 | 08:01 PM
I am perfectly fine with you distributing this Rob, I trust you with a lot more then just a few wiring documents . [This puts two of us in an awkward situation ]. Just make sure it is within reason and that the other person knows why it had to be done privately.
For people wondering:
The entire reason that these are being held private is that these are paid for documents that have strict copyright laws. This is another reason why I am yet to publicly mention the names/sources of which I got the information from. You know, the whole Freedom > Jail thing
Old Mar 19, 2012 | 10:21 AM
nekkidlad's Avatar
i bet u had to pay abe lincoln so he would tell billy mays so he'd ask a favor from cptn. kirk and mr. spock to dance battle with harry and lloyd and serve them so mr t in the croud would say "I PITY THE FOOLS, WHO JUST LOST THIS DANCE BATTLE!", so zack morris(who loves hearing that catch phrase) would pause time so you could just walk into the library of congress and use your 3-d night vision goggles at the top of the clock tower and read your map to find the secretly marked hidden moveable brick where these documents are located behind, and all because u've had it w the mf'n bad info on every other mf'n place...?
.....correct..?
Old Mar 19, 2012 | 10:25 AM
roblaza's Avatar
Wrong.
johnjonfenomeno
178
Jan 7, 2026 09:18 PM
ankl98
Lancer How Tos / Installations
10
Feb 28, 2013 07:04 AM
rhitme03
Jun 6, 2011 01:50 PM
benji
34
Jun 4, 2009 07:31 PM
Sr20kidD
May 6, 2007 06:40 PM
