View Poll Results: Rate this FlipFlop Trunk Modification
Top honors
18
52.94%
Good, but others are better
11
32.35%
Works, but design isn't so hot
5.88%
Stinks. Do not like it with green eggs and ham
8.82%
Voters: 34. You may not vote on this poll
Flip Flop Trunk Modification (new solution)
Old Mar 23, 2007 | 10:40 PM
bsc7080emn's Avatar
Talking Flip Flop Trunk Modification (new solution)
Well after much reading and perusing the net, I put together a design that is in-expensive, easy to do, and applicable to many vehicle trunk designs. Materials will run about 20-30 bucks and a few hours work. In the end, you have what I think is a very professional looking install that is reversible in the event you opt to sell the vehicle and what to restore the trunk back to stock operation.
What do you think? Later in the thread I posted a more detailed DIY guide
Old Mar 23, 2007 | 10:57 PM
Q8_EVO's Avatar
Looks good
Old Mar 23, 2007 | 11:35 PM
ThunderOZ's Avatar
Has it raised the trunk any when closed? Like is the trunk still sealed well?
Old Mar 23, 2007 | 11:39 PM
CityKnight's Avatar
Damn it!
I had heard there was a simpler way, and I couldnt figure it out!
I did it differently and said F* it, but "thats" how I wanted to do it!
+1 Way cool.
You'll see mine here: https://www.evolutionm.net/forums/sh...lip-Flop+Trunk
bsc7080emn's Avatar
Does it seal properly
Yes it seals properly. What you need to do when you bolt down the c-channel to the trunk lid is make sure you countersink it level to the c-channel. Then its really no different than if you did have it all... we are talk about a few millimeters extra in height only, thus no leaks. As in anything, depends on your personal skill level and willingness to take your time. Time I had, skill... well it was an experiment... hence the reason I used aluminum. I could have made the channels from steel as well... but aluminum was much easier to work with for certain.
Old Mar 23, 2007 | 11:43 PM
bsc7080emn's Avatar
Change it...
I say... patch up the holes and redo it... clean and sweet. My opinion only though. BTW... thanks for the props.
Originally Posted by CityKnight
Damn it!
+1 Way cool.
Old Mar 23, 2007 | 11:49 PM
EvoDan2004's Avatar
i gave it top honor's but i feel it can be done a bit cleaner. meaning not so ruff looking. somthing a simple sander can fix or a wire wheel. otherwize A++++
Old Mar 23, 2007 | 11:51 PM
CityKnight's Avatar
nevermind.. question answered.
Old Mar 23, 2007 | 11:53 PM
ThunderOZ's Avatar
Damn it!
+1 Way cool.
yea i started to do it your way but just didnt want to drill into my trunk...still have the parts at my house from like the summer
Old Mar 24, 2007 | 12:05 AM
bsc7080emn's Avatar
Sand it down more...
Agreed.... if left as brushed aluminum... I painted mine flat black so it would not be the focus of the trunk lift... looks more integrated now instead of aftermarket.
Old Mar 24, 2007 | 12:07 AM
EvoDan2004's Avatar
nice. good job bro.
Old Mar 24, 2007 | 12:08 AM
bsc7080emn's Avatar
Holes in trunk
I didn't want to drill holes in trunk either, so I didn't do anything till I could figure out a better way. Now the only holes drilled are in the support arms... 3 on each.... nothing more, nothing less.
Old Mar 25, 2007 | 07:03 PM
ohfourLancer's Avatar
thats pretty sweet.
Old Mar 25, 2007 | 07:16 PM
TheShortBus's Avatar
looks good
Old Mar 25, 2007 | 08:42 PM
ThunderOZ's Avatar
ok heres a question...IF those pins (the ones you are supposed to pull out) come out while ur driving for some reason or another will it effect anything?
