Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
cost of spring install??!
Old Jan 12, 2003 | 10:51 PM
02Lancer's Avatar
do it yourself.... would recommend a spring compressor to take off stock springs, you can get a good one for 35 bucks at autozone (mcpherson strut spring compressor). by myself, i installed my ground control adj. ht. coil over kit with eibach springs in about 3 hours... 2 hours or so to install, and and hour to get the right height at all four corners. you'll save some money and have the satisfaction of doing it yourself. good luck
Old Jan 12, 2003 | 11:12 PM
rrozul09's Avatar
Speedline(here in washington) installed mine for $100 w00t.
Old Jan 13, 2003 | 05:23 PM
psmokie68's Avatar
when i was taking the stock springs off, it jumped a lil bit, but i didnt need to use anything to hold the spring so it wouldnt jump, it barely did, but like i said, 02izzel, need help, i'd be more than welcome too!
Old Jan 14, 2003 | 01:26 PM
2002lancer-OZ's Avatar
do you have to have a impact gun to remove/install springs?? if so can you rent it from somewhere? I know it might be a stupid ? but oh well.
Old Jan 14, 2003 | 05:21 PM
psmokie68's Avatar
um.....
Old Jan 14, 2003 | 07:44 PM
azyan's Avatar
psmokie, i had the spring jump once also, but it was on a 91 accord. haha me and boys drop car at home. shop alway be ripping people off around here!
Old Jan 14, 2003 | 08:17 PM
hardcoretuner's Avatar
did my myself and forgot to put the rubber thing that goes over the spring and attaches to the top the thing that goes between that anyway now when i hit a bump thats massive you hear metal hit metal OUCH!! you might be thinking alex why not just take it off and redo it well i tried this and my friend who was helping me used an 11/16 for some reason and rounded every single nut on the top of the strut with an impact gun, mitsu wants 40 per nut to fix so i must save, everyday though i try to use some visegrips or anything but nothing works i am screwed
Old Jan 14, 2003 | 09:28 PM
psmokie68's Avatar
i have a lil problem after i installed my springs, but i dont think its my springs, i think its the way i put my wheels back on. it makes that noise when you move as if you had your emergency brake on.
carlmoore3
Apr 2, 2013 07:04 PM
Kahrs
May 5, 2011 09:11 AM
evol911
Northwest Region
Feb 19, 2011 10:27 AM
Rough 01
21
Sep 2, 2010 04:04 PM
nikkadanny
19
Jan 5, 2007 10:08 AM
